1 members (78buckshot),
112
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,136 Posts1,056,425 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#58023 03/20/2006 2:38 AM | Joined: Jul 2005 Posts: 15 Junior Member | | Junior Member Joined: Jul 2005 Posts: 15 | I replaced the stock exhaust manifold on my 235 with twin fentons and lost the automatic manifold heat as a result. The truck has stalled twice due to (I think) carb iceing shortly after start up. (When hot, it runs fine). Here is my solution and please let me know if it is really stupid. I made a 3/32 thick aluminium cover for the base of the intake manifold that seals the void below the carb. My plan is to plumb two 3/8 " compression fittings to the plate at the base of the intake manifold and run two 3/8 aluminium lines to the heater intake and return outlets on the water pump. That should provide 50 degree water under the carb when cold (18 degrees above freezing) and 180 degree water when the engine is fully warmed. (which should be about the temp of most of the engine. Do you think this will cause vapor lock problems at the high end or some other problem that I might have missed. Any suggestions are welcome. Thanks Mike | | |
#58024 03/20/2006 3:06 AM | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | I did basically the same thing following advice from a member here - thanks 4onthefloor! I used a thermostat housing and water pump from a 261 and ran the by-pass thru the intake which I made out of 5/16" brake line. I made the plate for the bottom of my intake out of 4" x 4" piece of 5/16 flat bar. Here are some pics http://community.webshots.com/album/360111285YfkRkF | | |
#58025 03/20/2006 2:36 PM | Joined: Jul 2005 Posts: 15 Junior Member | | Junior Member Joined: Jul 2005 Posts: 15 | Bigmacdaddy; You are a master craftsman! I hope do do half as well. Mike | | |
#58026 03/20/2006 4:37 PM | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | I wouldn't go that far! I'm a shadetree mechanic at best. The stuff I do is usually done with help from the guys here and I am fortunate to have a neighbor who is an ace mechanic that shows me how to do this stuff. The main point is, if I can do it, anyone can! My real job (beer plumber) does involve a lot of fittings and making sure things don't leak and that definately came into play on this project. | | |
#58027 03/20/2006 8:12 PM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Mike, you're right on target but you need a heavier target. Make the cover plate from 1/4" or heavier material so you can drill and tap for 1/4" NPT. The 3/32" alum is much too thin and harder to seal.
You can also buy this part from some of the vendors. | | |
#58028 03/20/2006 10:42 PM | Joined: Oct 2003 Posts: 90 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2003 Posts: 90 | Nice job bigmac, I may have to rig up something similar, I don't have a fenton manifold. I split mine myself. I cut the factory heat riser flap out as it was froze up. Should'a left it in I guess, but that's one neat lookin' piece of plumbin' resto44 | | |
#58029 03/21/2006 1:19 AM | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | I'm just about to start building a 261 with help from my neighbor and you guys or course. I'm thinking of having my original manifold split and using the stock heating set-up. I have put it on a shelf since I put the fentons w/ the 235. This way I can build all the way to the exhaust pipes while my truck is still usable. On the other hand, I think my plate and lines will match the Edelbrock 2 x 1 I will be using. Also, the Edelbrock is aluminum and will heat up faster than my stock intake does with water. Hmmm...Decisions, decisions.... | | |
#58030 03/21/2006 1:25 AM | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | Hey Mike, I almost forgot. You may already know this, but fitting your manifolds and heating components is SO much easier if you do it on a mock-up head on a bench. Just one more thing my neighbor taught me. | | |
#58032 03/22/2006 4:57 PM | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | Use black RTV for a sealant. There is a string of posts under the topic, "heated intakes" from last April, 2005. Good info there. | | |
#58033 03/22/2006 10:41 PM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Take bigmacdaddy's advice, seal the plugs and search for old discussions about "Offenhauser" intakes.
I have a water-heated two-carb Offenhauser on a 261 that has never leaked BUT other people have found that those plugs do leak.
Tim | | |
#58034 03/22/2006 11:29 PM | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Thanks, i will do the search, i was getting too tired last night to do so.Thanks again!!! 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
#58035 03/25/2006 4:37 AM | Joined: May 2005 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 45 | This is a permanent fix for any leaking bottom plugs on the Offy 2x1 or 3x1 intakes. If I done this link below correctly,(??it's my first try), the pictures tell the procedure. I have a few of these slugs already punched out of the correct size aluminun. If anybody needs a pair, just e-mail me and ask. There is no charge for them, as long my supply last. http://community.webshots.com/user/OldFartEd | | |
