5 members (Southerntruck, Goach2, Hanks custodian, Otto Skorzeny, 1955 1 Series), 111 guests, and 3 robots.
Topics128,192
Posts1,057,251
Members48,466
#572336 09/08/2009 2:19 AM
I haven't run into this before, buy I have oil dripping from the exhaust manifold at hte gasket.
Any thoughts on whqat is wrong?
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
What year and what kind of engine do you have?
If it is truly coming from the exhaust, then you should have a blue smoke from the exhaust. Pull the plugs and inspect for oil fouling. If your exhaust is clean and clear then most likely the valve pan is leaking and just running down and around.
Sure it's not just a black water trail, condensation, coming from an exhaust leak?
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
OK, it is a 216 in my 52 Chev, 1 ton.
Exhaust smokes blue, plugs are black.
I have three spots on the block where there are drips building up.
In a recent valve job, I replaced the valve seals, used NOS valves, ground and lapped them but did not knurl the guides. I suspect either the valves are leaking oil into the cylinders or the rings are bad.
1946 1-ton Panel
either of your suspicions could be right, I would suspect the rings. neither is good news unfortunately.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Thats not good news Mike.
I know where there is a 235 in MN if your interested.
Scott,
I have one located in Freedom that I was going to rebuild last spring. I decided to try and save the 216 and not to go through a rebuild but it looks like it is not going to work out. Strange thing is I had good compression after the valve job. All except one at 120 and one at 110. Not the best, but acceptable. I will do another one when I get a chance and see what, if anything has changed. Also there was almost no ridge in the cylinders when I had it apart. I didn't bother to mic them at that time and it looked like they still had some cross hatching on the walls from a honing.
1946 1-ton Panel
valve guides would show good compression, yet leak oil from the top. So would bad valve seals.
That makes sense. Valve closed, cylinder sealed, Valve open and oil can flow into the cylinder from the head. Gues I have to decide if I want to re-do the head and try it or just rebuild a 235.
1946 1-ton Panel
Mike did you ever get this fixed???
Jaime
