| | | Forums66 Topics128,009 Posts1,055,295 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 166 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 166 | 1 dent and two holes in the oil pan going up the mountain. Is she toast or worth trying to fix ? Thanx ! cheerz ! | | | | | Joined: May 2009 Posts: 181 'Bolter | | 'Bolter Joined: May 2009 Posts: 181 | too vague... Drop the pan and have a look. or just peek through the holes!!
Bryan 1954 3104 235 "AD" L-6 3-on-the tree
| | | | | Joined: Aug 2008 Posts: 230 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 230 | probably lost a rod !unless the oil pump pick up got wound up in the crank and smacked the oil pan . | | | | | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | Oil pan holes usually mean broken-off rods, and they can spin around inside and do a BUNCH of damage- - - - - -broken piston skirts, holed cylinder walls, and definitely a scored crankshaft. You've probably got a boat anchor there! Jerry
