6 members (Peggy M, tclederman, TexasJim50, baldeagle, Gray_Ghost, greenie-reddy), 60 guests, and 9 robots.
Topics128,020
Posts1,055,345
Members48,419
#571023 09/03/2009 8:18 PM
I
I Offline
1 dent and two holes in the oil pan going up the mountain. Is she toast or worth trying to fix ? Thanx ! cheerz !
too vague...
Drop the pan and have a look. or just peek through the holes!! smile
Bryan
1954 3104 235 "AD" L-6 3-on-the tree
probably lost a rod !unless the oil pump pick up got wound up in the crank and smacked the oil pan .
Oil pan holes usually mean broken-off rods, and they can spin around inside and do a BUNCH of damage- - - - - -broken piston skirts, holed cylinder walls, and definitely a scored crankshaft. You've probably got a boat anchor there!
