7 members (cmayna, klhansen, joe apple, Hotrod Lincoln, Peggy M, 2 invisible), 151 guests, and 0 robots.
Topics128,114
Posts1,056,282
Members48,439
#567976 08/24/2009 4:11 PM
I have a 1953 216 CID engine that need the exhaust manifold bolts replaced. First how do I remove the old bolts and second where can I get replacement bolts.
Thanks in Advance
Charlie
1953 5 Window
1994 Harley, Heritage Softail Classic
2006 Chevy Colarado
I didn't say it was your fault, I said I was blaming you.
If you think you can actually remove them try using PB Blaster. It comes in an aerosol can and is available in parts stores. If not,which is very likely, go to the Tech Tips page here and look under the Engine category for manifold Bolt Removal for how it's done.
Drew
Thanks Drew, I search the forum before I ask didn't think to check Tech tips. Where can I get replacement studs?
1953 5 Window
2006 Chevy Colarado
Charley, I got mine at the local Ace Hardware. They have the "regular" ones which will strip out if your not careful. Be sure they are at least grade 5 but I would use grade 8.... the store here also has some that are heat treated and tough! I'd also put a dap of anti-sieze on them.
If you want to change out to studs instead of bolts, I believe these are the Dorman numbers. I haven't had a chance to try this yet on my 235, but I plan to.
Qty Length Dorman #
2....1.5...675-098
2....4......675-008
4....2......675-003
8....Nuts...867-012
regards,
Leon
Dave and Alvin,
Thanks for the info, I plan on working on them this week end.
Charlie
1953 5 Window
2006 Chevy Colarado
Make sure you use some Anti Sieze when you replace them. Sooner or later you're going toahve to take them out again and with this stuff you'll be glad you used it when the time comes. This is the voice of experience talking.
dj durant
More pix on Flickr
Save yourself a ton of headache in the future and get the Brass Nuts also!
Tim
1952 Chevy Shortbed
Photos in Photobucket
def anti seize! 'cause i violently curse the person before me that didn't use it on exposed condenser fan motor shafts. and when you get older like me, anti geeze is great for memory problems
