7 members (TUTS 59, Bill Hanlon, papas52, Hotrod Lincoln, tclederman, BC59, 1 invisible), 105 guests, and 2 robots.
Topics128,119
Posts1,056,313
Members48,439
#552645 07/04/2009 8:15 PM
Does anyone have a picture of an original ignition switch and the corresponding bracket that holds it behind the dashboard?
Id like to replace mine since its a universal type with a goofy little bezel that holds it in place. Im picky and it kinda ruins the look of the dash. Ive checked several trucks throughout my yard and only one Advanced Design truck has the original type of ignition switch, but the little bracket wont work since the Art Deco dash is a bit taller.
The vendors seem to carry the cylinder and keys, but I cant find anything about the original switch that holds the cylinder.
If I had a picture, it would probably make my search a bit easier, or I could try my hand at fabricating one.
Thanks, Jeff
My 1953 Chevrolet
1947.1 Gallery
I am not home but may be able to provide you one tomorrow.
1946 Chevrolet 1/2-ton
More pix on Photobucket
That would be great if you can find the time. Thanks.
My 1953 Chevrolet
1947.1 Gallery
Anyone?
My 1953 Chevrolet
1947.1 Gallery
I sent you a pm. Sorry for the delay. I have had computer issues and apparently still do. eek
Thanks Big Tee for the pics of the switch.
Can anyone confirm that an original switch has a small conduit with a wire inside going to the coil?
Thanks, Jeff
My 1953 Chevrolet
1947.1 Gallery
