0 members (),
97
Mod | | | Forums66 Topics128,143 Posts1,056,494 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Does anyone have a picture of an original ignition switch and the corresponding bracket that holds it behind the dashboard?
Id like to replace mine since its a universal type with a goofy little bezel that holds it in place. Im picky and it kinda ruins the look of the dash. Ive checked several trucks throughout my yard and only one Advanced Design truck has the original type of ignition switch, but the little bracket wont work since the Art Deco dash is a bit taller.
The vendors seem to carry the cylinder and keys, but I cant find anything about the original switch that holds the cylinder.
If I had a picture, it would probably make my search a bit easier, or I could try my hand at fabricating one.
Thanks, Jeff | | | | | Joined: Mar 2008 Posts: 374 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 374 | I am not home but may be able to provide you one tomorrow. | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | That would be great if you can find the time. Thanks. | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | | | | | | Joined: Mar 2008 Posts: 374 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 374 | I sent you a pm. Sorry for the delay. I have had computer issues and apparently still do.  | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Thanks Big Tee for the pics of the switch.
Can anyone confirm that an original switch has a small conduit with a wire inside going to the coil?
Thanks, Jeff | | |
