| | | Forums66 Topics128,087 Posts1,056,000 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 61 | Would you reccon to reuse the deflectors (# 13)? The one on the spindle doesn' t fit because of my new tapered roller bearing and it doesn' t make sense to me to use the other one on the hub. http://chevy.oldcarmanualproject.com/shop/1955truck2/55ctsm0302.htm
'59 Apache '67 Mustang
| | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Arent those tack welded to the backing plate?
Id see if you cant make them fit with a little effort. Any grease that escapes the seals would be thrown by centrifigul motion to the braking surface of the pads and drums.
Jeff | | | | | Joined: Sep 2007 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 61 | My deflector was between the spindle and the bearing race and not welded to the backing race. I decided to reuse these deflectors. Has anyone an idea how to fit it? http://img188.imageshack.us/my.php?image=1000535i.jpg
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | not really any 'fitting' involved - there's a slight shoulder at the back of the spindle, the shield sits on it [hole makes it snug, never seen one welded from the factory], the bearing and the back of the hub sit against it so it can't go anywhere .... not sure how tapered rollers would fit there, but if they sit in the hub the same way should work
Bill | | | | | Joined: Sep 2007 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 61 | The Problem is, when I put the grease seal on the new race (and in the hub), the deflector ist rubbing on the seal. On the old race (roller bearing) the grease seal was lower! Now I need help... http://img530.imageshack.us/my.php?image=bearing.jpg
