2 members (2-Ton, JW51),
67
Mod | | | Forums66 Topics128,055 Posts1,055,783 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 6 New Guy | | New Guy Joined: May 2009 Posts: 6 | hey guys new guy here I have a 51 chevy 3100 panel truck and I've been trying to get the body attached to the frame again. I have a door that has been wrecked and has a 3 inch in depth dent in it but the window still rolls up and down locks work ,everything is cool ,but I cant get the old bolts out of the door to get the components out ,all the rest of the bolts Ive gotten out I ve broken them so I'm expecting something bad to happen .On the positive side I have another door ready to go,just the door shell no copenents in it.The question is I thought of chopping the door half way down from the copenents down and use the donor half to replace the chopped half I would leave pics in the Gallery but I havnt figured out how to download pics yet Top
| | | | | Joined: Mar 2005 Posts: 267 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 267 | Penetrating oil and lots of it.
if you don't mind trashing the door i suppose that will work too. I don't remember having that much trouble stripping my doors though. I may have been lucky YMMV
I don't suffer from insanity, I enjoy every minute of it!
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Use impact driver (air) on low low pressure so as to tap tap tap on the bolt over and over, spray down with liquid wrench or equiv and gradually increase air pressure. Rubber hammer on surrounding area if you can, lightly, while doing this. Do you have 4 hands? Don't forget to put the driver in reverse!!!!
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the best trick - that most don't use - is always start removing rusty bolts/screws by tightening them with one good smuck [ratchet or impact driver], they'll usually turn just enough to break loose so you don't strip the head trying to get'em out .... if they still won't come out, tighten them until they break off
Bill | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Weld a screw to the heads and twist them out. If you have to drill them out you can always move up in size just a bit and use a pan head. It won't be counter sunk but if it means saving a door its worth its worth it.
Keep the penetrating oil sprayed on them for a day or two. Heck spray it down the inside of the door by sticking a "straw" down the window slot and soak it good. let us know how you make out......
Do you have a "parts panel"??? | | |
