2 members (frogfarmer, Otto Skorzeny), 102 guests, and 1 robot.
Topics128,154
Posts1,056,855
Members48,456
#542503 05/31/2009 10:54 PM
Hey all,
The hoist on my 1950 1.5 ton dump has gotten slow as it gets to the top, and sometimes you can hear the pump cavitating.
So, I'm thinking I need to add some hydraulic fluid. Got the bed up and securely propped. Then excavated all the gunk to find a fill plug ... with no luck.
Where in the heck do you add the oil? The only fill plugs I see seem too low.
Sorry for the silly question...
Some pictures:
The pump:
http://hubcap.clemson.edu/~willys/pump.jpg
The cylinder:
http://hubcap.clemson.edu/~willys/cyl.jpg
Thanks for any advice...
-Dan
It's the plug on top of the cylinder. Add some fluid and let the hoist down without the plug to be sure it's not over filled,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Have a look at the fluid. If water has gotten in, it will look like chocolate milk, not good!
Thanks, guys ... I felt pretty dumb for not just looking under that cover. Fluid looked like dirty oil (not water) and new fluid made things work fine. The pump leaks a little bit, but that's another project...
-Dan
