| | | Forums66 Topics128,149 Posts1,056,817 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 15 New Guy | | New Guy Joined: Nov 2008 Posts: 15 | Hey all, The hoist on my 1950 1.5 ton dump has gotten slow as it gets to the top, and sometimes you can hear the pump cavitating. So, I'm thinking I need to add some hydraulic fluid. Got the bed up and securely propped. Then excavated all the gunk to find a fill plug ... with no luck. Where in the heck do you add the oil? The only fill plugs I see seem too low. Sorry for the silly question... Some pictures: The pump: http://hubcap.clemson.edu/~willys/pump.jpg The cylinder: http://hubcap.clemson.edu/~willys/cyl.jpg Thanks for any advice... -Dan | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | It's the plug on top of the cylinder. Add some fluid and let the hoist down without the plug to be sure it's not over filled, Scott
| | | | | Joined: Feb 2009 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 137 | Have a look at the fluid. If water has gotten in, it will look like chocolate milk, not good! | | | | | Joined: Nov 2008 Posts: 15 New Guy | | New Guy Joined: Nov 2008 Posts: 15 | Thanks, guys ... I felt pretty dumb for not just looking under that cover. Fluid looked like dirty oil (not water) and new fluid made things work fine. The pump leaks a little bit, but that's another project...
-Dan | | |
