| | | Forums66 Topics128,205 Posts1,057,425 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2004 Posts: 52 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 52 | Does anyone know the dimensions of the bottom of our 47-53 chevy/gmc truck cabs? I am hoping to go pick up a cab that is 3 states away and know that my 4-cylinder Toyota Tacoma doesn't like pulling a 5x10 utility trailer that far, but I will if I have to. I am wondering if there is any imaginable way (tilting, sitting on TOP of the fenders, loading sideways..etc..) to get a cab to fit in that back of my tiny toyota. Yes I could measure my cab myself, but as usual I am out of town on business and won't be back for a few weeks. So I want to know soon. Thanks!!!
Whether you think you can or can't, you're right.
Also--in 2004, I invented the spotting alert network in stovebolt after seeing so many trucks when driving around. So that means I am cool.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | No, that would be an insult to the Chevy! DG
Denny G Sandwich, IL
| | | | | Joined: Sep 2007 Posts: 141 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 141 | I don't think that it will fit. So I would consider using a couple of 2x12 boards, or a piece of 3/4" or thicker plywood, or maybe a pallet, and tie down one of the above on top of the bed rails of the "sake sipper", then placing the body on top, tied down as well. The hardest thing will be getting the cab up that high. chris ioakimedes Fairfax, California Don Quijote was right! | | | | | Joined: Nov 2006 Posts: 677 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 677 | No, that would be an insult to the Chevy! DG  Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs. 1951 3100 350 TBI Gallery Toddzilla... "$old" | | | | | Joined: Jan 2008 Posts: 493 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 493 | I hauled just the cab with no hood or fenders on the bed of my 82' S-10. I mounted it through the front mounts to a 2x6 and tied the back mounts to a 2x6 with some baling wire and set the 2x6's across the bed sides. That put it up kinda high but not to bad. It looked kinda strange but it rode just fine for about 30 miles. But that was with a Chevy not a Toyota. I also tied the crap out of it to the bed. I wish I had taken the picture. Scratching my S-10 was not an issue new scratches just add to the patina. Also leave the boards long enough for some large folks to grab on to then saw them off once you get it on the bed. lots of folks is better if just to help steady it.
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I'm thinking that the cab will sit pretty tall in the back of your pickup. It might create a significant amount of wind resistance. You might find the drive more pleasant pulling the trailer.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I hope I'm not following if you use Mt Tam's method. I'm sure you don't have any anchors strong enough to hold the chains you need to keep it from blowing off when meeting a semi or bus.
That said, and AD cab is nearly 6 feet wide and 4 feet 2 inches long at the bottom quickly extending to 5 feet. It might fit sideways in an F-250 but I don't know about a Tyoater. You'd still have the tiedown problem. | | | | | Joined: Oct 2004 Posts: 348 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 348 | i always use a 4 by 8 garden or motorcycle trailer from u haul they have a tailgate that lowers down and they are low to the ground i think they have 8 or 10 inch wheels, take some 2 by 6 studs to go across the low bed sides and strap it down well | | | | | Joined: Oct 2004 Posts: 348 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 348 | i think the trailers are local only dont tell them where your going | | | | | Joined: Sep 2007 Posts: 141 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 141 |
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Nope. Can't Do it. Won't work. Impossible.  | | | | | Joined: Apr 2008 Posts: 33 Apprentice | | Apprentice Joined: Apr 2008 Posts: 33 | rent a real truck and go get it.
Actually the trailer idea would be the best way to go.
Be American, Buy American
| | | | | Joined: Sep 2001 Posts: 272 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 272 | Too risky way TOOOOOO top heavy. Rent a uhaul trailer about $50-60 day one way. I am going to get a 16ft 4wheel trlr when I get the 56 cab in 2 weeks. 4wheel is more stable and less wind drag, less chance of rolling your toy and toyota due to HIGH center of gravity. It's a lot easier to get chains tied downed too. Brad | | | | | Joined: May 2009 Posts: 13 New Guy | | New Guy Joined: May 2009 Posts: 13 | I hauled a 54 GMC cab in the back of my 55 1st series 3100 from Sacramento to Reno rode just great. An early example of a classic "double cab".  | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I've trailered a few cabs, but never put on in the back of a pickup. I've considered it but don't like the weight that high and my experience with tall loads is they dramatically reduce fuel economy, enough that on a long trip it the reduced fuel consumption might pay for the trailer rental.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Aug 2005 Posts: 113 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 113 | I carried a '55 cab (big window) in the back of my 2003 Chevy 2500HD from Oregon to Alberta 2 years ago. It sat sideways in the bed, but there wasn't a lot of spare room.
As far as weight and being top heavy, it wasn't too bad. there was no glass in it (no doors either) so all the weight was located in the lower part of the cab.
Lane | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | I hauled a two ton front end and with two doors to boot in the back of my Dakota. Made a framework of two by six to set it on and strapped the crap out of it. No problem. Only went a couple of hundred miles and a ferry ride. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: May 2007 Posts: 4 New Guy | | New Guy Joined: May 2007 Posts: 4 | Probably a good idea to just put it on the trailer. Even if it fit in the bed, transporting it that far, it would definitely be much more safe to put it on your trailer. I would.
Chris | | |
