1 members (homer52), 66 guests, and 4 robots.
Topics128,072
Posts1,055,906
Members48,429
#539610 05/21/2009 12:45 AM
Hello, I'm new. I just bought a 66 C-60. The previous owner recently put a new master cylinder on, the old one was leaking. He bled and adjusted the brakes. But you have to pump the brakes 3 times to get a good pedal. When you do this you get a good firm pedal and the truck stops good. The previous owner pumped about 2 gallons of brake fluid through the system trying to solve this problem. I have checked his work and find nothing wrong. What do I try now? Thanks
It's possible he didn't properly bench bleed the master cylinder before installing it.
Welcome to the Stovebolt Forums. There is a forum just for big trucks like yours named Big Bolts. I'm moving your post there.
You'll have to bleed out the hydro-vac before bleeding at the wheels. Power bleeding is the only way to go on these hydro trucks,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
i just finished my c60 brakes i had a problem like your mine was the vent inside the cab check and make sure its not blocked and you can hear the hydrovac working {a sucking noise when you step on the brakes} double check brake adjustments
hope that helps
perry
1963 Chevy C60 Apache Dump Truck
Stovebolt Gallery Page
Photobucket pictures
Check the brake adjustment first. If memory serves you have an adjuster for each shoe so make sure you adjust both shoes on each wheel. I jack the wheel up and adjust the shoes until they drag slightly.
Remember 9-11-01--God Bless the USA
JUSTICE, not REVENGE, will prevail
1951 Chevy 1/2-ton Pickup truck
