0 members (),
85
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 9 New Guy | | New Guy Joined: May 2009 Posts: 9 | Hello, I'm new. I just bought a 66 C-60. The previous owner recently put a new master cylinder on, the old one was leaking. He bled and adjusted the brakes. But you have to pump the brakes 3 times to get a good pedal. When you do this you get a good firm pedal and the truck stops good. The previous owner pumped about 2 gallons of brake fluid through the system trying to solve this problem. I have checked his work and find nothing wrong. What do I try now? Thanks | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | It's possible he didn't properly bench bleed the master cylinder before installing it.
Welcome to the Stovebolt Forums. There is a forum just for big trucks like yours named Big Bolts. I'm moving your post there. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | You'll have to bleed out the hydro-vac before bleeding at the wheels. Power bleeding is the only way to go on these hydro trucks, Scott | | | | | Joined: Jan 2009 Posts: 86 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 86 | i just finished my c60 brakes i had a problem like your mine was the vent inside the cab check and make sure its not blocked and you can hear the hydrovac working {a sucking noise when you step on the brakes} double check brake adjustments hope that helps perry | | | | | Joined: Jan 1970 Posts: 365 Shop Shark | | Shop Shark Joined: Jan 1970 Posts: 365 | Check the brake adjustment first. If memory serves you have an adjuster for each shoe so make sure you adjust both shoes on each wheel. I jack the wheel up and adjust the shoes until they drag slightly. | | |
