1 members (Otto Skorzeny), 81 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#536307 05/10/2009 12:41 AM
hey guy's just wondering if any body has put power steering on a 1961 or similar gmc stock 4x4 ? mine is stock height (tall )and it's a bit tough to move 10.5x 31 tire's (they hardly fill the wheel wells). i haven't seen any kits ,i don't know if you can use any stock component's in the process or not .thank,s ahead of time if any body has any input ,price is a object as i am not able to work any more .
old dog #536531 05/11/2009 1:14 AM
I wonder if it's the same as the 2wd truck? can you compare a pictures to the ones in my webshots albumC if they are, then you're in like Flint. I'd like to work with another member on the switch. Can you post a link tp a pictures of the frontend?
1960 GMC 305A V-6 Gallery Page
Remember, the government cannot give --anything to anyone --that they have not first taken away from someone else.
BUY AMERICAN http://www.stillmadeinusa.com/index.html
Modelman #536547 05/11/2009 2:23 AM
I think you need to use a box from a 67-87 4X4 truck, but installing it is the same technique as the 2wd trucks,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Modelman #536561 05/11/2009 2:43 AM
i will try to take a couple of picture's tomorrow .we will see how they come out .i just took a couple pictures here's the link http://picasaweb.google.com/wildbill017/200802Feb?authkey=Gv1sRgCO7nu8_O_-vYXg&feat=directlink
old dog #536705 05/11/2009 7:07 PM
just posted a link with pictures on other post
old dog #536834 05/12/2009 3:46 AM
Nope, It's totally different than the stock 2wd model. Does not mean it can't be done I just don't know how.
Jake
Modelman #536846 05/12/2009 4:19 AM
I think you'll have to use a 4X4 box that's 90 degrees from the frame when centered. Then you'll have to make or modify a drag link to connect the newer box to the steering arm. Probably will require a REZ bracket too,
Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
i guess i will keep looking i will figure some thing out ,thanks for the replies .
