| | | Forums66 Topics128,012 Posts1,055,318 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2008 Posts: 230 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 230 | hey guy's just wondering if any body has put power steering on a 1961 or similar gmc stock 4x4 ? mine is stock height (tall )and it's a bit tough to move 10.5x 31 tire's (they hardly fill the wheel wells). i haven't seen any kits ,i don't know if you can use any stock component's in the process or not .thank,s ahead of time if any body has any input ,price is a object as i am not able to work any more . | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | I wonder if it's the same as the 2wd truck? can you compare a pictures to the ones in my webshots albumC if they are, then you're in like Flint. I'd like to work with another member on the switch. Can you post a link tp a pictures of the frontend?
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I think you need to use a box from a 67-87 4X4 truck, but installing it is the same technique as the 2wd trucks, Scott | | | | | Joined: Aug 2008 Posts: 230 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 230 | just posted a link with pictures on other post | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | Nope, It's totally different than the stock 2wd model. Does not mean it can't be done I just don't know how.
Jake | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I think you'll have to use a 4X4 box that's 90 degrees from the frame when centered. Then you'll have to make or modify a drag link to connect the newer box to the steering arm. Probably will require a REZ bracket too, Scott | | | | | Joined: Aug 2008 Posts: 230 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 230 | i guess i will keep looking i will figure some thing out ,thanks for the replies . | | |
