1 members (Gray_Ghost),
65
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,073 Posts1,055,908 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 57 'Bolter | | 'Bolter Joined: May 2005 Posts: 57 | Just broke my driver's side repop wing handle. That's both sides now, and the passenger side broke when I was trying to install the pin! Got these from a reputable truck parts dealer, with whom I've been satisfied otherwise. Anyone know of a source of GOOD repops, or perhaps be able to tell me that there are good used ones that don't need rechromed,maybe out west? | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | For some NOS I would try giving Obsolete Parts a call down in Ga. Ty has a lot of NOS stuff and it isn't always in his catalog. Other than that your at the mercy of the vendors which do carry them. Give JimCarter a call since he is close to you....maybe put and AD in the Parts Wanted forum and see if a bolter may have a nice set. | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | | | | | | Joined: May 2005 Posts: 57 'Bolter | | 'Bolter Joined: May 2005 Posts: 57 | Thanks for the heads up. I suppose I'd better get used to the idea of rechroming a set of originals! | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | Your post did not say how they broke was it the pin that keep the handle on? If so, one thing you may try is slowly re-drilling the pinway grove for a bigger rod/pin. The original was a small hollow tube when was split down the length. Up grade to a harden material.
If the handle it self broke thet must be something restricting and causing serious drag, it take a bit of pressure to move those things.
Jake
| | | | | Joined: Feb 2005 Posts: 199 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2005 Posts: 199 | Hey Ratskin, what do you won't to pay for a set of NOS GM vent handles? Thanks, Hobert
"The Lord is my shepherd"
| | | | | Joined: May 2005 Posts: 57 'Bolter | | 'Bolter Joined: May 2005 Posts: 57 | These broke the casting, right where the pin goes through. I've got new rubber, and was probably using too much pressure to try to lock them. Hobert, you've got a PM. | | |
