1 members (Shaffer's1950), 85 guests, and 2 robots.
Topics128,196
Posts1,057,391
Members48,469
Junior Member
Junior Member
Has anyone compiled a list of vehicles that would
make a good donor for swapping axles onto Chevy trucks? And if not, someone should.
The reason I ask is because I have a '95 Grand Am in my driveway that I have no use for, other than to salvage the parts. Is there any chance the axles would be usefull to put on my '52 Chevy 1/2 ton?
I will do a search of the site and web for the info but if someone else knows off hand the info would be appreciated.
Anonymous
Unregistered
Anonymous
Unregistered
Isn't that pontiac a front wheel drive? If so then it would not be a very good candidate.
There are several web sites that have the axle information. One of the most helpful is http://50chevy.freeservers.com/
Junior Member
Junior Member
doh!! I should have at least thought of that.
thanks for pointing it out.
Crow: I put a 1969 Grand Prix axle on the back of my 59 31.
popcorn The Truth is Out There (good luck mine was an easy swap) Ben
You Tube
I'm very happy with the '73 Chevelle wagon rear under my '55 1st. Fits under there just right. Of course I had to cut the coil and 4-link stuff off and weld on spring pads.
i am happy with my 79 nova with a 2.73 rearend, in my 54/3100/235. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Joe, I guess your using a later model trans with open drive shaft. If you can find a rear end out of a 55 2nd or later that a good choice. If you plan to haul a lot of weight I'd suggest a 4:10 ratio, also you can use your 6 hole wheels.
resto44-
