| | | Forums66 Topics128,187 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#53285 12/09/2005 8:22 PM | Joined: Nov 2000 Posts: 44 Junior Member | | Junior Member Joined: Nov 2000 Posts: 44 | Has anyone compiled a list of vehicles that would make a good donor for swapping axles onto Chevy trucks? And if not, someone should.
The reason I ask is because I have a '95 Grand Am in my driveway that I have no use for, other than to salvage the parts. Is there any chance the axles would be usefull to put on my '52 Chevy 1/2 ton?
I will do a search of the site and web for the info but if someone else knows off hand the info would be appreciated. | | |
#53286 12/09/2005 8:26 PM | | Anonymous Unregistered | | Anonymous Unregistered | Isn't that pontiac a front wheel drive? If so then it would not be a very good candidate. There are several web sites that have the axle information. One of the most helpful is http://50chevy.freeservers.com/ | | |
#53287 12/09/2005 8:40 PM | Joined: Nov 2000 Posts: 44 Junior Member | | Junior Member Joined: Nov 2000 Posts: 44 | doh!! I should have at least thought of that. thanks for pointing it out. | | |
#53288 12/09/2005 9:08 PM | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | Crow: I put a 1969 Grand Prix axle on the back of my 59 31.
popcorn The Truth is Out There (good luck mine was an easy swap) Ben | | |
#53289 12/09/2005 10:25 PM | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 |
1952 1300 Canadian 1/2 ton restomod You Tube | | |
#53290 12/10/2005 6:03 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I'm very happy with the '73 Chevelle wagon rear under my '55 1st. Fits under there just right. Of course I had to cut the coil and 4-link stuff off and weld on spring pads.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#53291 12/10/2005 2:54 PM | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | i am happy with my 79 nova with a 2.73 rearend, in my 54/3100/235. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
#53293 12/13/2005 12:54 AM | Joined: Oct 2003 Posts: 90 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2003 Posts: 90 | Joe, I guess your using a later model trans with open drive shaft. If you can find a rear end out of a 55 2nd or later that a good choice. If you plan to haul a lot of weight I'd suggest a 4:10 ratio, also you can use your 6 hole wheels.
resto44- | | |
