2 members (Hush, delky), 141 guests, and 0 robots.
Topics128,126
Posts1,056,354
Members48,441
#531841 04/24/2009 11:40 PM
Apprentice
Apprentice
No this is not a cliche ;-)
Seriously, I have a 64 C10 and I am under the suspicion that the rearend on my truck is not original. Mostly because the track arm has a different mounting on all the catalogs that I look at for parts, also it has the two piece driveshaft and the mounting for the bearing looks "homemade" Here are some pictures.
http://i677.photobucket.com/albums/vv140/1964c10/P1020120.jpg
http://i677.photobucket.com/albums/vv140/1964c10/P1020119.jpg
I would sincerely appreciate any help in finding out what is going on so that I can replace the bushings on the track arm.
It looks like someone modified the carrier bracket to accomodate a different style carrier bearing. The tracking arm is a panhard bar and it looks right to me,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Apprentice
Apprentice
Scott,
Thanks for the info. The panhard bar in the catalog mounts to a pin/bolt that is in the rear axle as you can see in the pictures, mine has a bracket welded to it. I have seen a similar bracket sold to adapt a "modern" axle to our trucks.
That panhard bracket looks just like the one on my 62...dont know why somebody would do that to the newer rear though ohwell
Apprentice
Apprentice
Well not sure it's "new" that was just my assumption since it was different from stock but I guess it could be from an older one as well. Would it be possible to get a picture from you Mark?
