4 members (1955 1 Series, klhansen, Rusted Nut, 1 invisible), 111 guests, and 2 robots.
Topics128,159
Posts1,056,901
Members48,458
#531541 04/24/2009 1:21 AM
http://www.flickr.com/photos/surfhunter/ here it is 64 chevy chop top 350 4 bolt balanced 10 to 1 flat top pistons 202 heads comp cam eldebrock air gap manifold 750 eld carb lots of other cool stuff enjoy but don't look too close at my messy garage. thanks Troy
I get "gr8whitecustoms doesn't have anything available to you." ohwell
Where's The Fotos?
David Colter
pics * 1954 wrecker * [color:#009900]1948 Chevy 1-Ton[/color]
54TOW #531556 04/24/2009 2:05 AM
thats what I got to......
come on Merrill, I want to see the pix grin
click the link, what picts I got popped right up for me. may not show if you are not running same photo software? will post more after the brakes are done so I can pull it forward.hope you can open the picts. good luck Troy. (just figured it out I think you have to join the flicker software then the picts open.)
Former Workshop Owner
Looks like you have quite an interesting project. thumbs_up
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
Hi Merrill,just checked out your pics....It's lookin' good!
Nice to see some more of you 60's truckers joining up.
BTW the garage doesn't look too bad!
You should see mine just now! dang
More pix on Flickr.
check out the new pictures.
Looks good, where will you source a new front window?
1959 Chevy Apache
1948 Chevrolet COE
Trucks are like womens handbags !! you can never have enough of them and they can carry all your worldly possesions
not sure the glass guy that was recommended took my side window and is not to be found 2weeks now.phone is full and wont take messages. hope I find him to at least get my side glass back.
digging this up...just curious how much chop, & any updates?
4 inch chop. got the glass in. I have been driving it a little just tore the front end off to do a disc brake conv. Having some problems finding tie rod ends to convert to a 76 disc front end.
i'm just now checking back in, but i appreciate the response...how much did it cost to have your glass cut, & what source did you use? also, did you keep the vents for the side glass?
oh, and how much is your truck lowered?
thanks!
Perhaps this link will help you with the tie rod ends:
http://67-72chevytrucks.com/vboard/showthread.php?t=405330&highlight=tie+rod+ends
1960 GMC 1/2-Ton Pickup Truck
Updates in the DITY Gallery
