| | | Forums66 Topics128,162 Posts1,056,937 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 9 New Guy | | New Guy Joined: Apr 2009 Posts: 9 | http://www.flickr.com/photos/surfhunter/ here it is 64 chevy chop top 350 4 bolt balanced 10 to 1 flat top pistons 202 heads comp cam eldebrock air gap manifold 750 eld carb lots of other cool stuff enjoy but don't look too close at my messy garage. thanks Troy
| | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | I get "gr8whitecustoms doesn't have anything available to you." Where's The Fotos? | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | thats what I got to...... come on Merrill, I want to see the  | | | | | Joined: Apr 2009 Posts: 9 New Guy | | New Guy Joined: Apr 2009 Posts: 9 | click the link, what picts I got popped right up for me. may not show if you are not running same photo software? will post more after the brakes are done so I can pull it forward.hope you can open the picts. good luck Troy. (just figured it out I think you have to join the flicker software then the picts open.)
| | | | | Joined: Nov 2004 Posts: 2,420 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,420 | Looks like you have quite an interesting project. John
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Hi Merrill,just checked out your pics....It's lookin' good! Nice to see some more of you 60's truckers joining up. BTW the garage doesn't look too bad! You should see mine just now!  1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Apr 2009 Posts: 9 New Guy | | New Guy Joined: Apr 2009 Posts: 9 | check out the new pictures. | | | | | Joined: Sep 2007 Posts: 140 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 140 | Looks good, where will you source a new front window? | | | | | Joined: Apr 2009 Posts: 9 New Guy | | New Guy Joined: Apr 2009 Posts: 9 | not sure the glass guy that was recommended took my side window and is not to be found 2weeks now.phone is full and wont take messages. hope I find him to at least get my side glass back. | | | | | Joined: Jun 2009 Posts: 11 New Guy | | New Guy Joined: Jun 2009 Posts: 11 | digging this up...just curious how much chop, & any updates? | | | | | Joined: Apr 2009 Posts: 9 New Guy | | New Guy Joined: Apr 2009 Posts: 9 | 4 inch chop. got the glass in. I have been driving it a little just tore the front end off to do a disc brake conv. Having some problems finding tie rod ends to convert to a 76 disc front end. | | | | | Joined: Jun 2009 Posts: 11 New Guy | | New Guy Joined: Jun 2009 Posts: 11 | 4 inch chop. got the glass in. I have been driving it a little just tore the front end off to do a disc brake conv. Having some problems finding tie rod ends to convert to a 76 disc front end. i'm just now checking back in, but i appreciate the response...how much did it cost to have your glass cut, & what source did you use? also, did you keep the vents for the side glass? oh, and how much is your truck lowered? thanks! | | | | | Joined: Dec 2008 Posts: 337 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 337 | 4 inch chop. got the glass in. I have been driving it a little just tore the front end off to do a disc brake conv. Having some problems finding tie rod ends to convert to a 76 disc front end. Perhaps this link will help you with the tie rod ends: http://67-72chevytrucks.com/vboard/showthread.php?t=405330&highlight=tie+rod+ends | | |
