| | | Forums66 Topics128,288 Posts1,058,581 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 8 New Guy | | New Guy Joined: Mar 2006 Posts: 8 | I have searched the forums and can't find where someone says how to remove the steering column from the steering box. Maybe it is not possible, if not, then do I have to remove the steering wheel and pull the cab over the steering column? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The column doesn't separate from the box. The easy way to do it would be to remove the steering wheel, pitman arm, and the 3 bolts holding the box to the frame, then remove the steering box assembly before you remove the cab.
Bill Burmeister | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | The shop manual explains how to remove wheel, steering wheel, disconect horn wire, steering rod in order to remove steering box/column. It will all come out from the bottom side. | | | | | Joined: Apr 2000 Posts: 199 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 199 | Can you remove the box and leave the pitman arm on it? I would have thought the shafts could be taken off the ball joints but I can't get them apart on our '52 3100. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | We have been through this a few times before and some people say you can remove the whole works with out getting the truck up on a lift. I don't have a lift, by the way. I've looked at this a dozen times and that just does not look possible. I'd sure like to see a couple of pictures of one being dragged out the bottom with the cab and engine still on. Mostly to just see what was used to get the truck up high enough to get the gear out. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | Denny, I did it but the fenders/inner and outer were off and the weheel. I could turn/twist it around pretty good and I guess you could say I brought it out the "side" at an angle. | | | | | Joined: Apr 2000 Posts: 199 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 199 | How does the steering linkage come off? I ended up taking the pitman off. | | |
