2 members (Bill Hanlon, 1 invisible),
62
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,679 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | A friend of mine has a great set of hole punches for gasket material and the like. He thought he saw a set at Sears, but I havent had any luck finding anything like that locally. Has anyone bought a set recently? His set came in just about every fractional size from 1/32" to 5/8" or larger. Ive used sharpened pieces of tubing before (and that only goes so far), but Id just as soon commit to a nice punch set.
Thanks, Jeff | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | I bought a set from here . They were less than $5 and work good.
Bruce | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | i got a set of blue point gasket punches in case pretty cheap used years ago. pretty good, they were even cheaper than the harbor freight set. might check into used. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I just used a set my nephew loaned me. They were from the Mac man but they are heavy and tough. No telling what those would coast oday. I don't see how you could go wrong for 5 bucks either !! | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Not as cheap as HF but they go up to 3/4" http://cgi.ebay.com/12p-PROFESSIONAL-Hollow-Punch-Set-Gasket-Leather-Metal_W0QQitemZ380115279354QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item380115279354&_trksid=p3286.c0.m14&_trkparms=66%3A2|65%3A10|39%3A1|240%3A1318 | | | | | Joined: Aug 2008 Posts: 403 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 403 | I have a HF set that I have used for 20 years and the trick to keeping them sharp is use a wood block under them as I have saw so many use them straight against a metal table then complain when they do not work very well. 62Blue Don
62Blue 62Chevy in progress You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I usually buy my leather/hand punches from McMaster Carr, they are expensive but made of good quality steel and properly heat-treated. I've never had one go dull on me and have used them a lot. The cheap sets that you get from HF or from the hardware vendors at the swap meets are simply low carbon steel. An attempt at heat-treating has been made in some cases but the case isn’t enough to keep the base metal from rounding over. I've picked up sets from both sources and find they go dull or out of shape after a few uses. And yes Don, I do back them up with maple blocks every time I use them and when I cut a fiber, rubber, felt washer or gasket it’s almost always in my small bench press where I can control the punch much better than slamming it a few times with a sledge hammer on the garage floor.
The old adage, "Ya get what ya pay for" applies here but if your only gonna use them a few times, then go for the cheap sets.
Denny Graham Sanwich, IL
Denny G Sandwich, IL
| | | | | Joined: Feb 2008 Posts: 102 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 102 | | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | i have the 27 piece set avaiable for use at work. it also sets up as a double punch which makes a perfect gasket for the cap on a master cyclinder. it also works nice to knock a hole in the glovebox outfitted with a rubber grommet for a plug and wires to pass thru for the sound system. this kit is the cats fine threaded nuts, i need to talk to the salesman that sold it to me because is was hundereds of dollars. the kit came in a nice little carrying case and says it was made in france. | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | I have a HF set that I have used for 20 years and the trick to keeping them sharp is use a wood block under them as I have saw so many use them straight against a metal table then complain when they do not work very well. 62Blue Don before i got the set i have now (which stays locked up and im the only one that has a key) we were able to resharpen them somewhat with the reamer on the ridged pipe threading machine. i also fount it will punch a nicer hole if the board is a 4x4 on end. | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | As anyone who has read my posts on HF,they know I do not like them. However a hole punch set for $5.I might give that a try.Cause its an item that I very seldom use.Just a thought. | | |
