2 members (Peggy M, UtahYork), 62 guests, and 1 robot.
Topics128,035
Posts1,055,443
Members48,422
#509105 02/22/2009 10:54 PM
Apprentice
Apprentice
My bed is going back together soon & I don't want to install the stock chains & hooks as these beat the paint to death, would not hold paint very well & just created a rusty looking mess.
I plan to use the slide barrels from MAR-K to secure the tailgate but the tailgate braces are a bit pricey. I have seen a few others that have used stock looking modern cables or folding flat bars. What works best, what did any you use & can you detail the install & from what type donor did the parts originate? Thanks.
Blue 666
A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools.
The chains don't have to be painted, and if the rubber chain covers are used, they won't beat the paint up. Just my 2 cents.
Samantha
1954 Chevy 3100
Picked from the Field
Follow in the DITY
I agree with Sam on this one, I installed the S.S. chains and clear rubber covers on mine with No Issues.
Tim
1952 Chevy Shortbed
Photos in Photobucket
Check out Mar-K and see what they are offering in the way of doing away with the chains. Besides the sliders, they also have the folding hinges and they look like they would do a great job.
dj durant
More pix on Flickr
Check out your local Marine Supply store. I used polished Stainless " Deck Hatch " latches. Welded the post portion into the top of the tailgate ( inside face ), and screwed the latch portion onto the inside of the box at the stake location. My tailgate seldom if ever gets opened, and this provided a clean solution for not much $$
1940 Chevy KC 1/2-Ton
I used mountain bike inner tube to cover my chains. Flexible and cheap, about $2.50 for the tube. I also punch a small hole in them where they bend so any water going into the tubes will drain out.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
How about adding cables to the tailgate? I went to Advance Auto Parts and picked up a pair of generic cables for $16.00.
I posted some pictures, click on the link in my signature line.
