0 members (),
68
8
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2008 Posts: 21 Apprentice | | Apprentice Joined: Oct 2008 Posts: 21 | My bed is going back together soon & I don't want to install the stock chains & hooks as these beat the paint to death, would not hold paint very well & just created a rusty looking mess.
I plan to use the slide barrels from MAR-K to secure the tailgate but the tailgate braces are a bit pricey. I have seen a few others that have used stock looking modern cables or folding flat bars. What works best, what did any you use & can you detail the install & from what type donor did the parts originate? Thanks.
Blue 666
A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools.
| | | | | Joined: May 2005 Posts: 334 'Bolter | | 'Bolter Joined: May 2005 Posts: 334 | The chains don't have to be painted, and if the rubber chain covers are used, they won't beat the paint up. Just my 2 cents. Samantha | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | I agree with Sam on this one, I installed the S.S. chains and clear rubber covers on mine with No Issues. Tim | | | | | Joined: Feb 2007 Posts: 435 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 435 | Check out Mar-K and see what they are offering in the way of doing away with the chains. Besides the sliders, they also have the folding hinges and they look like they would do a great job. | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Check out your local Marine Supply store. I used polished Stainless " Deck Hatch " latches. Welded the post portion into the top of the tailgate ( inside face ), and screwed the latch portion onto the inside of the box at the stake location. My tailgate seldom if ever gets opened, and this provided a clean solution for not much $$ | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | I used mountain bike inner tube to cover my chains. Flexible and cheap, about $2.50 for the tube. I also punch a small hole in them where they bend so any water going into the tubes will drain out. | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | How about adding cables to the tailgate? I went to Advance Auto Parts and picked up a pair of generic cables for $16.00.
I posted some pictures, click on the link in my signature line. | | |
