1 members (Hotrod Lincoln), 130 guests, and 2 robots.
Topics128,143
Posts1,056,494
Members48,442
#517255 03/15/2009 4:14 AM
I am looking to see what alternatives can be used for the radiator sized hose that runs from the neck of the fuel tank, up to the filler tube. i need both lines, the vent and the filler line replaced.
Before I buy, I wondered if there were alternatives.
56 stepside 3/4 ton longbed
Run down to your local store and check out their fuel filler hoses. Mine had a whole rack of different sizes and you could buy it by the foot.
Jeff
My 1953 Chevrolet
1947.1 Gallery
I had to go to a Hydralic repair shop to get replacement hoses.
Patrick
oreilly's carrys it but i had to ask several people and stores before i found someone who knew!!! rustednuts is right i bought it by the foot. made by gates i think. good luck
Make sure it is made for fuel as some hoses are not and will deteriorate quickly.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
