1 members (classicchevs),
101
Mod | | | Forums66 Topics128,093 Posts1,056,474 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2002 Posts: 159 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 159 | I am looking to see what alternatives can be used for the radiator sized hose that runs from the neck of the fuel tank, up to the filler tube. i need both lines, the vent and the filler line replaced. Before I buy, I wondered if there were alternatives.
56 stepside 3/4 ton longbed
| | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Run down to your local store and check out their fuel filler hoses. Mine had a whole rack of different sizes and you could buy it by the foot.
Jeff | | | | | Joined: Sep 2007 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 59 | I had to go to a Hydralic repair shop to get replacement hoses. Patrick | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | oreilly's carrys it but i had to ask several people and stores before i found someone who knew!!! rustednuts is right i bought it by the foot. made by gates i think. good luck | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Make sure it is made for fuel as some hoses are not and will deteriorate quickly. | | |
