1 members (delky),
130
Mod | | | Forums66 Topics128,062 Posts1,055,854 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2008 Posts: 82 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 82 | Hello,
I was just getting ready to buy the standard Sun Supertach II.
However, I thought that a gauge that goes to 8K RPM is sort of pointless for my old 235. Anyone find a good, legible-faced tach that has a lower scale?
Thanks!
1956 Chevy 3600 Dually
| | | | | Joined: Jan 2008 Posts: 239 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 239 | I have one in my box of parts to install that was intended for a diesel. I think it tops out at 4K, maybe 5, I don't remember for sure. The wiring is not the same as a standard tach, though so I'm not sure it will work.
Devin
If you can't hose it out it ain't a truck
55 3100 63 Corvair Monza 64 El Camino 72 240Z 01 Suburban
| | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | You might want to consider one of the older Sun Tachs. I see allot of them at the swap meets and on eBay. I've seen them from 2,000 RPM's up. These are the ones that have the under hood sending units that can be converted to modern technology to avoid having the batteries in the sending unit. Williamson's Instruments in Chester, Arkansas does the conversions.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Aug 2008 Posts: 82 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 82 | Thanks for the suggestions, guys. 55T, I did have my hands on a diesel tach a long time ago, and that particular tach would not work on my gas application at the time.
If anyone cares, I'm ordering the AutoMeter 2890 Tachometer. It's a 4K tach with black 2 5/8" housing. It should do the trick - legible but not huge.
| | | | | Joined: Jan 2009 Posts: 14 Apprentice | | Apprentice Joined: Jan 2009 Posts: 14 | I got one of those AutoMeter Tachs a few months ago. I think it is great. Besides having a reasonable scale, it is backlighted, and can be mounted on the steering column.
1951 Chevy 3100
| | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | I like it, too. I just wish it were available with a chrome bezel.
regards, Leon | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I did a search of Auto Meter tachs and found a 4K, 3 5k's, and a 6000 model. They are available but you have to look. Model 2508 is a 4K in 2-5/8" black that I liked. | | | | | Joined: Aug 2006 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 112 | Look for a tach drive distributor....rare, but easy to use.
64 & 66 GMC long fleetside 4x4 Cartwright, OK
| | | | | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 | This tach was given to me so the price was right and I used it. It goes to 8000 RPM which is probably way past redline for a 283 so I will set the movable shift indicator for the proper redline once I find out what that is. It is a Sunetune mini-tach with a 2 5/8 housing. Home made bracket. Weeds http://picasaweb.google.com/lh/photo/APK-zVJrsQUSsSHN0dDmog?feat=directlink | | | | | Joined: Apr 2006 Posts: 136 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 136 | Not to bust your chops, but, why would you put that in front of those awsome Dolphin gauges? Those are the coolest gauges. | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | OM51, Ya should see the HUGE 5" Sun Tach, with shift light mounted on my dash right next to the windshield seperator bar! My wife got it for me for X-Mas ...an I had to use it...ya know how that works..SHE WAS SO PROUD CHRISTMAS MORNIN..lol Tim | | |
