Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
7 members (DavidBraley, Otto Skorzeny, J Lucas, 66flea, Rosco, 55shaker, 1 invisible), 122 guests, and 5 robots.
Topics128,283
Posts1,058,504
Members48,490
Hey guys, I just bought a 1970 heavy half w/250cyl 4 speed in it. Every thing works & I drove it home. Now I am trying to identify everything. I have the motor (250 #F0918TAB) but having trouble w/trans & rear end. Trans is not orginal, it came w/three on tree. All I can find is GM 4 casting # is 3901127 & has granny low. Not sure about the rear end, is 12 bolt NF #3896838.Any help you can give a rookie would be grateful. Thanks
Jim
Leo Offline
Moderator
Moderator
Welcome Jim, this is where you can find out all you need to know about your old truck. I don't have GM's parts list but your transmission is likely a SM465. You could try asking this question in the engine and driveline forum. You will be surprised what you'll learn.
WElcome dodad: welcome to the stovebolt. right place to be.
Joy Offline
Welcome to Stovebolt!
Welcome to the "Bolt" !
2 Offline
Welcome to the Stovebolt, dodad70. wave
Terry K.
1951 5 window 1/2 ton
The only way to have a friend is to be one.
-Ralph Waldo Emerson-
Welcome to the bolt, sure like to see some pictures of your 1970 I have a 1971.
53 Panel: Thanks for the info! I tracked down the SM465 and the S/N match. Got 2 out of three now.
Jim
