3 members (Ponchogl, ShopRag, 52hornsby), 81 guests, and 2 robots.
Topics128,035
Posts1,055,564
#511831 03/01/2009 4:28 PM
hello guys, got a question for you, and need some suggestions.
as you might know, back in july of last year i put power dics brakes on my 57. everything was fine until a few months ago, when i started getting a very small leak from the master cylinder cover.
i took it off, cleaned everything, put it back on, and still, after a day of driving, i get a very small amount of brake fluid that will drip out of the cover, down the master cylinder, and onto my driveway.
it is a very very small leak, and dont affect the brakes at all.
so i ordered a new cover and seal, put it on friday, and it still has the small leak.
i dont have any other ideas.
it is not over full, about 1//4" full from the top.
any ideas, or has this ever happened to any of you ?
its a dual master and kit from performanceonline.
http://s251.photobucket.com/albums/...00/?action=view&current=DSC01566.jpg
http://s251.photobucket.com/albums/...00/?action=view&current=DSC01539.jpg
any leaks absolutly drive me crazy, and i would like to fix this some how, but i am ready to just leave it alone and add brake fluid when needed, which would probably be every year, since, like i said, the leak is so small.
oh yea, and the 2 retaining clips are new and hold the cover down really well.
thanks..
leonard
1957 Chevy 3100 1/2-Ton
Photobucket pictures
Could it be that the housing itself is slightly out of square?Lay a straightedge across it and check.Also was the mc a rebuild? mabe they machined the surface and it's lower thus not clamping as tight.Just my thought's.Tom
Riding in the Passing Lane
If it has a full bladder type seal it shouldn't leak but if you have air in the system or the rear brakes need adjusting it will shoot a lot of fluid back into the resorvoir when you release the brakes.
1972 Chevy c10 Cheyenne Super
There wasn't any need to put teflon tape on the brakelines either. That won't keep anything from leaking. It might make thinks harder to service in the future too,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
its a new master, so i doubt its that, but if i can get a straight edge on that surface next time i pull the cover, i will give that a try.
but i do know the 2 clamps do hold it pretty darn tight.
kind of wish now that i went with the firewall mount conversion also. its a lot easier to get to.
thanks.... leonard
full bladder type seal, meaning on the master cover ? it does have the full type seal with the master cover.
a few months ago my back brakes were way out of adjustment, but i adjusted them, so they should be fine, but maybe i will check the rear drum adjustments once again this week if i get a chance.
thanks for the input guys..
leonard
Scott
yes scott, i got some riff for the tape before... my stupidity. LOL.
thanks....leonard
Just a clarification on the teflon tape. It is not needed on brake line fittings, but the tape is needed on any of the adapters that are pipe threads.
Bleed the AIR out of the system...
The deception of ones' perception can interfere with the persistence of their existence
thanks lonnie and mechanic9.
there shouldnt be any air in the system, when i installed the kit i bled the heck out of all 4 brakes, so i will try the rear drum adjustment again first, but if it still leaks, then i will try to bleed again.
thanks much guys..leonard
Leonard,
Try this, I take it the cap has been for a bit, pop it off and check the gasket surface for a tiny skip on the sealing surface maybe there is a flaw on the master cyl. sealing surface? the gasket should show it.
A properly sealed and vented cap should not leak even with a few bubbles in the system, that is what the bladder and vent are for.
just my 2 pennies.
Tim
1952 Chevy Shortbed
Photos in Photobucket
Originally Posted by SW_Radial
Leonard,
just my 2 pennies.
Tim
thanks tim, i sure will check for defects in the sealing surface. its really kind of strange, since for the first 6 months everythign was fine,a nd now, for the past 3 months i am getting this small leak...strange.
thanks again.
leonard
Had the same problem on a 79 1 ton. I finally took the master cylinder and turned it upside down on a belt sander and trued the top of the reservoir chamber. This was a 6" wide shop sander not a portable belt sander. It solved the problem. Just like yours never a big leak more of a seep.
Jim
Jim
wow. amazing bill... thanks for that info.... i dread thinking baout having to pull the master to do that, but iff this little seep leak persists i guess i have no choice.
thanks a bunch for all your help guys.
leonard
sorry, i meant, thanks jim, farmer51....
One other possibility.You evidently have an under the floor mounted MC.You could have it mounted too close to an exhaust pipe,which in turn would raise the temp. of the brake fluid,causing it to expand and seep.
We are having problems just like you. On our '49 Chevrolet convertible, we used Dot5 fluid. We have all new brakes front to back. Just sitting having never been used the fluid is weeping out the master cylinder. We thought it might have been overfilled but it continued to leak. Even after removing some fluid it still weeps. Granted I'm not talking much but it kinda makes me mad when we have gone to all the trouble making sure everything is perfect. The only thing we can think of is it's the Dot5. ohwell
Bruce
My Trucks
Stuff I Collect
If you suspect that your top edge may not be true, I suggest looking at it with a straight edge and feeler gauge.
1951 1 Ton Completed
dale, i guess that could also be a possibility. the exhaust pipe is not real close, but next time i am driving around i will feel the master and get a feel for how hot it is getting.
thanks...
Bruce
yes, very strange huh ? i hate leaks, and since everything is new it should not be leaking.
i just checked, and i am running the new prestone synthetic DOT 3 fluid.
does that sound correct ?
thanks guys...
leonard
just one more thought....Could the cast iron be pourous? Like seeping through? Just another guess.Tom
grub #513138 03/04/2009 11:19 PM
wow tom, i sure hope not...wouldnt think so though..
thanks
leonard
