7 members (Oldcaliforniakid, jmoore, frogfarmer, Hotrod Lincoln, 49nut, Stovebolt48, mason86),
105
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,671 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | hello guys, got a question for you, and need some suggestions. as you might know, back in july of last year i put power dics brakes on my 57. everything was fine until a few months ago, when i started getting a very small leak from the master cylinder cover. i took it off, cleaned everything, put it back on, and still, after a day of driving, i get a very small amount of brake fluid that will drip out of the cover, down the master cylinder, and onto my driveway. it is a very very small leak, and dont affect the brakes at all. so i ordered a new cover and seal, put it on friday, and it still has the small leak. i dont have any other ideas. it is not over full, about 1//4" full from the top. any ideas, or has this ever happened to any of you ? its a dual master and kit from performanceonline. http://s251.photobucket.com/albums/...00/?action=view¤t=DSC01566.jpghttp://s251.photobucket.com/albums/...00/?action=view¤t=DSC01539.jpgany leaks absolutly drive me crazy, and i would like to fix this some how, but i am ready to just leave it alone and add brake fluid when needed, which would probably be every year, since, like i said, the leak is so small. oh yea, and the 2 retaining clips are new and hold the cover down really well. thanks.. leonard | | | | | Joined: Sep 2006 Posts: 206 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 206 | Could it be that the housing itself is slightly out of square?Lay a straightedge across it and check.Also was the mc a rebuild? mabe they machined the surface and it's lower thus not clamping as tight.Just my thought's.Tom | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If it has a full bladder type seal it shouldn't leak but if you have air in the system or the rear brakes need adjusting it will shoot a lot of fluid back into the resorvoir when you release the brakes. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | There wasn't any need to put teflon tape on the brakelines either. That won't keep anything from leaking. It might make thinks harder to service in the future too, Scott
| | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | Could it be that the housing itself is slightly out of square?Lay a straightedge across it and check.Also was the mc a rebuild? mabe they machined the surface and it's lower thus not clamping as tight.Just my thought's.Tom its a new master, so i doubt its that, but if i can get a straight edge on that surface next time i pull the cover, i will give that a try. but i do know the 2 clamps do hold it pretty darn tight. kind of wish now that i went with the firewall mount conversion also. its a lot easier to get to. thanks.... leonard | | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | If it has a full bladder type seal it shouldn't leak but if you have air in the system or the rear brakes need adjusting it will shoot a lot of fluid back into the resorvoir when you release the brakes. full bladder type seal, meaning on the master cover ? it does have the full type seal with the master cover. a few months ago my back brakes were way out of adjustment, but i adjusted them, so they should be fine, but maybe i will check the rear drum adjustments once again this week if i get a chance. thanks for the input guys.. leonard | | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | There wasn't any need to put teflon tape on the brakelines either. That won't keep anything from leaking. It might make thinks harder to service in the future too, Scott yes scott, i got some riff for the tape before... my stupidity. LOL. thanks....leonard | | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | Just a clarification on the teflon tape. It is not needed on brake line fittings, but the tape is needed on any of the adapters that are pipe threads. | | | | | Joined: Dec 2007 Posts: 6 New Guy | | New Guy Joined: Dec 2007 Posts: 6 | Bleed the AIR out of the system...
The deception of ones' perception can interfere with the persistence of their existence
| | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | thanks lonnie and mechanic9.
there shouldnt be any air in the system, when i installed the kit i bled the heck out of all 4 brakes, so i will try the rear drum adjustment again first, but if it still leaks, then i will try to bleed again.
thanks much guys..leonard | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Leonard, Try this, I take it the cap has been for a bit, pop it off and check the gasket surface for a tiny skip on the sealing surface maybe there is a flaw on the master cyl. sealing surface? the gasket should show it. A properly sealed and vented cap should not leak even with a few bubbles in the system, that is what the bladder and vent are for. just my 2 pennies. Tim | | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | Leonard, Try this, I take it the cap has been for a bit, pop it off and check the gasket surface for a tiny skip on the sealing surface maybe there is a flaw on the master cyl. sealing surface? the gasket should show it. A properly sealed and vented cap should not leak even with a few bubbles in the system, that is what the bladder and vent are for. just my 2 pennies. Tim thanks tim, i sure will check for defects in the sealing surface. its really kind of strange, since for the first 6 months everythign was fine,a nd now, for the past 3 months i am getting this small leak...strange. thanks again. leonard | | | | | Joined: Mar 2006 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 53 | Had the same problem on a 79 1 ton. I finally took the master cylinder and turned it upside down on a belt sander and trued the top of the reservoir chamber. This was a 6" wide shop sander not a portable belt sander. It solved the problem. Just like yours never a big leak more of a seep.
Jim | | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | Had the same problem on a 79 1 ton. I finally took the master cylinder and turned it upside down on a belt sander and trued the top of the reservoir chamber. This was a 6" wide shop sander not a portable belt sander. It solved the problem. Just like yours never a big leak more of a seep.
Jim wow. amazing bill... thanks for that info.... i dread thinking baout having to pull the master to do that, but iff this little seep leak persists i guess i have no choice. thanks a bunch for all your help guys. leonard | | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | sorry, i meant, thanks jim, farmer51.... | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | One other possibility.You evidently have an under the floor mounted MC.You could have it mounted too close to an exhaust pipe,which in turn would raise the temp. of the brake fluid,causing it to expand and seep. | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | We are having problems just like you. On our '49 Chevrolet convertible, we used Dot5 fluid. We have all new brakes front to back. Just sitting having never been used the fluid is weeping out the master cylinder. We thought it might have been overfilled but it continued to leak. Even after removing some fluid it still weeps. Granted I'm not talking much but it kinda makes me mad when we have gone to all the trouble making sure everything is perfect. The only thing we can think of is it's the Dot5.  Bruce | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If you suspect that your top edge may not be true, I suggest looking at it with a straight edge and feeler gauge. | | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | One other possibility.You evidently have an under the floor mounted MC.You could have it mounted too close to an exhaust pipe,which in turn would raise the temp. of the brake fluid,causing it to expand and seep. dale, i guess that could also be a possibility. the exhaust pipe is not real close, but next time i am driving around i will feel the master and get a feel for how hot it is getting. thanks... | | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | We are having problems just like you. On our '49 Chevrolet convertible, we used Dot5 fluid. We have all new brakes front to back. Just sitting having never been used the fluid is weeping out the master cylinder. We thought it might have been overfilled but it continued to leak. Even after removing some fluid it still weeps. Granted I'm not talking much but it kinda makes me mad when we have gone to all the trouble making sure everything is perfect. The only thing we can think of is it's the Dot5.  Bruce yes, very strange huh ? i hate leaks, and since everything is new it should not be leaking. i just checked, and i am running the new prestone synthetic DOT 3 fluid. does that sound correct ? thanks guys... leonard | | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | | | | | | Joined: Sep 2006 Posts: 206 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 206 | just one more thought....Could the cast iron be pourous? Like seeping through? Just another guess.Tom | | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | just one more thought....Could the cast iron be pourous? Like seeping through? Just another guess.Tom wow tom, i sure hope not...wouldnt think so though.. thanks leonard | | |
