10 members (JW51, Gdads51, artinva, Peggy M, VicZ, Ridgeback, RAC1812, Shaffer's1950, klhansen, 1 invisible),
122
0
Mod | | | Forums66 Topics128,077 Posts1,055,928 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#51129 10/14/2005 2:52 AM | Joined: Sep 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Sep 2005 Posts: 310 | Hi Gang, did anyone ever build in a blockheater in to an engine that old? We go to minus 40 or further and I want to drive the truck in every month of the year.We can be plus 15 during the day and minus 25 during the night, so I would not be able to use the truck from November till May, a heated shop is not a posible solutions with the energy prices as they are now. Thanks for any input
Richard | | |
#51130 10/14/2005 2:58 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Implement stores sell dipstick heaters and oil pan heaters. Does a '28 have core plugs? If so, measure it and get a block heater for it. Just a thought, Scott | | |
#51131 10/14/2005 8:08 AM | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | My preference is the freeze-plug heater. Be careful how you route the cord,install it exactly as the directions recommend,and use the shortest,thickest extension cord possible,to get the most efficiency. Speed | | |
#51132 10/14/2005 4:48 PM | Joined: May 2003 Posts: 328 Shop Shark | | Shop Shark Joined: May 2003 Posts: 328 | I have seen heaters that install in your radiator hose. They heat and recirculate the coolant. I can't remember where I saw them though. You might try a google search.
Phil
Never hold your farts in. They travel up your spine and into your brain...that is where crappy ideas come from.
#51133 10/15/2005 3:02 PM | Joined: Sep 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Sep 2005 Posts: 310 | Thanks Guys, that waterheater thing sounds good I can take it out when it gets warmer and be "original" again, I'll do a search. I have an oilpanheater but it doesn't do a great job, I use it as aditional heater on the Dodge. Dodge is getting oilpump problems, but that comes with the age I guess
Richard | | |
