5 members (Oswald, FAST55, Bill Hanlon, 2 invisible), 85 guests, and 2 robots.
Topics128,075
Posts1,055,918
Members48,429
Hi Gang,
did anyone ever build in a blockheater in to an engine that old? We go to minus 40 or further and I want to drive the truck in every month of the year.We can be plus 15 during the day and minus 25 during the night, so I would not be able to use the truck from November till May, a heated shop is not a posible solutions with the energy prices as they are now.
Thanks for any input
Richard
Implement stores sell dipstick heaters and oil pan heaters. Does a '28 have core plugs? If so, measure it and get a block heater for it.
Just a thought,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
My preference is the freeze-plug heater. Be careful how you route the cord,install it exactly as the directions recommend,and use the shortest,thickest extension cord possible,to get the most efficiency.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
I have seen heaters that install in your radiator hose. They heat and recirculate the coolant. I can't remember where I saw them though. You might try a google search.
Phil
Never hold your farts in. They travel up your spine and into your brain...that is where crappy ideas come from.
Thanks Guys,
that waterheater thing sounds good I can take it out when it gets warmer and be "original" again, I'll do a search. I have an oilpanheater but it doesn't do a great job, I use it as aditional heater on the Dodge. Dodge is getting oilpump problems, but that comes with the age I guess
Richard
