5 members (IHPWR, Peggy M, 55shaker, 1955 1 Series, 1 invisible), 78 guests, and 1 robot.
Topics128,211
Posts1,057,468
Members48,471
I'm new in STOVEBOLT, my question is, i have a 1953, 5 window 3100 chev. truck, but the original motor is shot, can i fit a 400cc motor to replace the one that i have, and if i have to modefied any thing, trying to keep the 3 speed trany, original as much as i can, please reply.
(This is before i buy the motor)
Hector
Leo Offline
Moderator
Moderator
Welcome Hector. I'm assuming your engine is a 400 ci, not cc. I think there are several types of 400's out there. Not likely an easy swap, but I'll let more experienced guys explain it.
welcome, the 400 motor is a good choice.chev being the smallest,size is compact and will go fairly easy, v8 crossmember is a must for motormounts.pontiac or olds will fit but needs more work,relocate stearing box ect.years ago my dad fit a 303 olds in 53 gmc 1/2 ton.he made exhaust manifold for left side to clear stearing box.best of luck with your bolt
Not likely you will be able to keep any of the drive train original. Certainly not the enclosed drive shaft. With enough money and skills or a good fabricator anything can be put into your truck. Open your wallet and have at it.
Its not hard to put in a V8 but certain changes are needed and depending on your access to other "stuff". I despised the crossmember for motor mounts. Buy the ones from JimCarter/Chassis Engineering and make a nice neat clean job. Locate them on the chassis per instructions and that V8 will fit like a glove.
...and yes, I'd plan on moving the steering box outside the chassis and its not that hard either if you follow the instructions from a couple places.
...if you go V8 save your self some time and money by going ahead and putting in a 700R4 Tranny. Take your time and make yourself a neat smooth ride.....and yes, change out the rearend.
Nothing to it smile (you can check out my photobucket link for some pics)
