7 members (wilbur53, 1955 1 Series, SmalltownTRKGuy, Jon G, ShopRag, Southerntruck, 60steve),
113
Mod | | | Forums66 Topics128,212 Posts1,057,468 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 2 New Guy | | New Guy Joined: Feb 2009 Posts: 2 | I'm new in STOVEBOLT, my question is, i have a 1953, 5 window 3100 chev. truck, but the original motor is shot, can i fit a 400cc motor to replace the one that i have, and if i have to modefied any thing, trying to keep the 3 speed trany, original as much as i can, please reply. (This is before i buy the motor)
Hector
| | | | | Joined: Mar 2007 Posts: 4,217 Moderator | | Moderator Joined: Mar 2007 Posts: 4,217 | Welcome Hector. I'm assuming your engine is a 400 ci, not cc. I think there are several types of 400's out there. Not likely an easy swap, but I'll let more experienced guys explain it. | | | | | Joined: Feb 2014 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2014 Posts: 46 | welcome, the 400 motor is a good choice.chev being the smallest,size is compact and will go fairly easy, v8 crossmember is a must for motormounts.pontiac or olds will fit but needs more work,relocate stearing box ect.years ago my dad fit a 303 olds in 53 gmc 1/2 ton.he made exhaust manifold for left side to clear stearing box.best of luck with your bolt | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Not likely you will be able to keep any of the drive train original. Certainly not the enclosed drive shaft. With enough money and skills or a good fabricator anything can be put into your truck. Open your wallet and have at it.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Its not hard to put in a V8 but certain changes are needed and depending on your access to other "stuff". I despised the crossmember for motor mounts. Buy the ones from JimCarter/Chassis Engineering and make a nice neat clean job. Locate them on the chassis per instructions and that V8 will fit like a glove. ...and yes, I'd plan on moving the steering box outside the chassis and its not that hard either if you follow the instructions from a couple places. ...if you go V8 save your self some time and money by going ahead and putting in a 700R4 Tranny. Take your time and make yourself a neat smooth ride.....and yes, change out the rearend. Nothing to it  (you can check out my photobucket link for some pics) | | |
