| | | Forums66 Topics128,068 Posts1,055,882 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 17 Apprentice | | Apprentice Joined: Jul 2008 Posts: 17 | What is the consensus on what to do with parts that were previously zinc coated. i.e. door latches, hood hinges, window regulators, etc.
Let me clarify, I try to use original parts so typically they will need to be media blasted, wire brushed, etc.
| | | | | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | If the parts are not going to show, i usually hit them with a rattle can primer to slow the rust process. If they show, i use a variety of different rattle can colors. I have used aluminum, cast iron, iron, etc. There is even a zinc paint. There are many metal sprays, and on some parts, i just clean them and leave them alone. It depends on the look you want on each piece. I wouldn't get to far away from the original color, because if you get a scratch, it'll show to much. Cecil........ | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | door latches and a few other parts will look really good if you buff them to a nice shine. They will look like stainless and you can put a coat of clear on them so it'll last. | | |
