5 members (mick53, Grandpa C., lumbersawyer, Nick in Manitou, Wally / Montana), 127 guests, and 3 robots.
Topics128,264
Posts1,058,357
Members48,485
#509663 02/24/2009 3:43 AM
Apprentice
Apprentice
What is the consensus on what to do with parts that were previously zinc coated. i.e. door latches, hood hinges, window regulators, etc.
Let me clarify, I try to use original parts so typically they will need to be media blasted, wire brushed, etc.
If the parts are not going to show, i usually hit them with a rattle can primer to slow the rust process. If they show, i use a variety of different rattle can colors. I have used aluminum, cast iron, iron, etc. There is even a zinc paint. There are many metal sprays, and on some parts, i just clean them and leave them alone. It depends on the look you want on each piece. I wouldn't get to far away from the original color, because if you get a scratch, it'll show to much. Cecil........
door latches and a few other parts will look really good if you buff them to a nice shine. They will look like stainless and you can put a coat of clear on them so it'll last.
