0 members (),
179
Mod | | | Forums66 Topics128,277 Posts1,058,456 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 289 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 289 | I was trying to cut some 18 ga steel today with my jig saw (skill variable speed) and it just kept spitting out the blades. It's tooless to install the blade, just slide the collar up and instert the blade. Blades stayed until I started cutting and yes I was using metal blades. Last I used this was for notching some 2x6's and it worked fine a few months ago. 5 or 6 years ago I cut a window hole into a PC case cover and it worked fine.
Any idea what's wrong? | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Eric,
My first thought would be some debris in the doohickey that locks the blade to the saw. If the lock mechanism worked as it should, even with a blade jammed or friction welded in a cut, it seems like it should jerk your hand and the saw up and down before it ever released the blade.
I would take a real close look at the locking mechanism and look for dirt or crud. Spray some brake-kleen on it and a little shot of oil.
Stuart | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | or maybe the last blades you got aren't designed for the model of saw?
Bill | | | | | Joined: Feb 2007 Posts: 434 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 434 | Just to check, what is the TPI (tooth per inch) on the blades? The higher that number, the better it should cut metal.
I cut some metal with mine, sometimes it does some wierd stuff, like kicking back on tight circles, and sparking at the blade. A cutoff wheel seems to work better, or the plasma cutter if I have a pattern (I can't freehand all that well).
R-Bo
1959 Apache 1/2 ton Big Window, Short bed Fleetside (under reconstruction) 1966 GMC 305V6 in the family
| | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Eric, Do the metal cutting blades you got have the extra "little ears" on them for use with the tooless chuck on your jig saw ? | | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | think i agree with red on this one...............dave 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I had a craftsman POS quick change set-up that wouldn't keep hold of the blades too. It was a cheesy design that only worked in theory. I replaced it with a conventional style saw, Scott | | | | | Joined: Oct 2006 Posts: 289 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 289 | Hi All,
I have the same blades I have used for years and the package says "for Skill U-Lock collar" and I was using blades that said for metal.
I tried cleaning up the mechanism with PB blaster and then with electro-motive aerosol cleaner, similar to brake-kleen. No help.
I put in a multi-purpose blade and cross cut a 2x4, no sweat. Then back too a metal blade and cut 1" long in some 11 ga. I think maybe it came out once. After all that, it still wouldn't cut the 18 ga. Either the saw is gummed up or going bad or the steel was just too flimsy. Time will tell I suppose. Got out the cutting torch and made hay on the 18ga. Then I had to grind the slag off. Think i'll just stick to 3" cut-off wheels. All this so I can have some metal to learn to use my Mig Welder (Hobart 187 - .023 wire on gas & polarity correct). So far, I'm pretty good at blowing holes with the welder, but I remain optimistic and have a couple people that can give me hands on advice. If I can't get the hang of it on the thin stuff I'll cut up some of 11ga and give that go. I'll keep you all posted on that, but in a new thread. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I've got that saw. It relies on some friction between the collar and the blade to hold it in place, and if you get any oil on it it stops working right. Also, the slot can get wallowed out. It locks a bit better if you file the front of the blade into a K shape.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Oct 2006 Posts: 289 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 289 | I'll clean it up, try the K slot and report back.
Thanks, | | | | | Joined: Oct 2006 Posts: 289 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 289 | I tried cleaning it out with carb cleaner and then rubbing alcohol, but it was a notch on the back side of the blade that made it stay. Just sort of cut a V in using the edge of the bench grinder. Lot faster than filing. I tried the front, (tooth side) of the blade, that didn't work as well as the back side.
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | I think the trick to a jig saw is to keep Your work pic from vibrating try to clamp the pic between 2 2by 4s and run the saw up against the wood so You metal is not moving up and down with the saw blade worked for Me ,Pete | | | | | Joined: Dec 2007 Posts: 166 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 166 | Pete52,s idea,Reds idea. SW Radial and R Bo,s idea. CHA CHING ! If that don,t work I,d fling er in the ol can, after I pulverized it with my SludgeHammer and sent a few M-80,s up its ying yang. Then off to Home Depot to get a new one,...problem solved.  | | |
