| | | Forums66 Topics128,035 Posts1,055,445 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 95 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 95 | Need help with exact location of the accessory tail lights offered simalar to the 39 chevy style.
Sully
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | For a 1948 Suburban? Here's the template. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | tim...to make it work don't you have to "mirror" it for "the other side"? I've stuck this template up to my panel and while I "know" where it goes I'm just not that darn sure...am I making sense? ...or is it I just hate to put a punch mark in the new paint  | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Alvin, Here is a drawing with the template in place. Yes, you would turn the template over when marking the other side. I understand the fear associated with drilling these holes. Mark the holes with chalk and then place the lamps holders over the holes (to assure yourself that the location is correct). Tim | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Tim, what a swell guy you are!! That makes it easy and also calms my nerves....just a little. I printed it out so I won't loose it! I'll have to make a pad out of some material.
** I bought a set of the Chrome bullet lights from the guy in Oregon. Didn't you buy a set?? or was it Weeds or Gmoniz. You know, half price of what most vendors want...and they are good. | | | | | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 | Sully and Alvin, I was lucky enough to find a pair of original bullets at a swap meet here in Wisconsin. I used Tim's template to drill the holes and they fit perfectly. I can't vouch for the stud location on the reproductions but I would check if there are any differences between the stud locations on the template and the repro before i did any drilling. Pics of mine on Picasa. Weeds | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | I put a set of the repros on my suburban,,the template matched up perfect. | | | | | Joined: Feb 2009 Posts: 95 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 95 | Wow: Burb heads, thank you!The install and fab work is easy,i could not recall seeing any here in the south with them and was'nt sure of the height.
Sully
