1 members (baldeagle), 23 guests, and 5 robots.
Topics128,037
Posts1,055,466
Members48,424
#507925 02/19/2009 11:17 PM
V
V Offline
Hey All,
Looking to get the 'bolt out of the garage this spring!
Can anybody recommend a "sloshing sealer", or offer any tips for cleaning/sealing my gas tank? A forum search yielded no results.
Here's one product I found:
http://www.theshopproducts.com/products_gastank-sealer.html
Thanks!
-tyler
1959 3200 Apache Fleetside
In the Legacy Gallery
vtapache #507951 02/20/2009 12:07 AM
Riding in the Passing Lane
Persnally I dont like them. If it starts comeing loose you will be in a worse mess. If a new tank is readily available for your model I think that is the way to go. If its minor rust you can put a in line filter under the tank & check it often at first. If its serious rust & there is no replacement available use the sealer but follow directions to the T & dont rush it.
1972 Chevy c10 Cheyenne Super
V
V Offline
Thanks, WBR.
A second, more thorough search of the forums turned up many discussions of this topic.
vtapache #508020 02/20/2009 2:31 AM
I have used a similar product in the tank of my '39, unfortunately it was 30 yrs ago and I dont remember the name of it , however , during the 6 yrs that I used it as my work truck, there was never another problem with the fuel delivery or storage.
ps, similar product is used in aircraft wing tanks as sealer, no problems there either.
Dusty #508028 02/20/2009 3:16 AM
I used a product like that on my first truck, a 67 datsun. My Dad and I sealed the gas tank, worrying about rust... The truck sat for a year while we rebuilt the enigne, and yes there was gas in the tank- not so good. The sealer began lifting and coming off in sheets. We eventually cut a big hole in the top of the tank, and cleaned it out, and welded it shut. It was safely done though.
That being said, the fault must have been ours, as airplane guys and gals use it all the time. Frankly if its used in an aircraft, it probably is good enough for me.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
Mr. Lang #508057 02/20/2009 4:00 AM
Heres a link to a few posts when I did mine.
Burning the tank out with acid.
Sealing the tank.
Im very happy with how it came out. Hasnt been a problem yet and I doubt it will be. I spent an awful lot of time prepping it which I think is the key to applying the sealer correctly and the main reason why other sealers fail.
Always remember safety if you decide on the acid route!
Jeff
My 1953 Chevrolet
1947.1 Gallery
