1 members (baldeagle),
62
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 453 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 453 | I ordered new "U" shaped brackets for my leaf springs and it came with the rivots needed to hold them in place. Can I just drill out the old rivots? Also, is heat needed to put on the new ones? Or do I just smash the rivot end with a hammer making sure the end is flush against the leaf? If so...is there special tools needed for this?
Thanks much, ~Ron | | | | | Joined: Aug 2008 Posts: 230 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 230 | are you talking about the clip straps that rivet to the spring ? if so just grind the old rivet head off at the clip and drive it out with a punch .the new rivet just slid through the clip strap and into the spring ,there should be a recessed area on the top of the leaf ,use a hammer and pound the rivet flush .it's no graded steel . | | | | | Joined: Apr 2006 Posts: 453 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 453 | | | |
