3 members (Wally / Montana, Guitplayer, Jon G), 126 guests, and 1 robot.
Topics128,130
Posts1,056,717
Members48,454
#506529 02/16/2009 5:19 PM
1 Offline
Decided to pull the bearings out of the Tranny but I am having a problem with he front bearing. It has a "Cutch gear bearing retainer nut" that screws onto the input shaft and holds everthing. It has two holes on either side, and I am sure there is some simple method for unscrewing this from the shaft but I am unable to figure it out or dont have the right tool. Any suggestions? Thanks guys.
1951 Chevy 3100 5 window with a 1958-60 235 and original 4 speed.
Purney,
There is a simple shadtree procedure to accomplish this. Secure the clutch gear in a vise with soft jaws and using a drift punch, tap the retainer off, unscrewing it in a normal CCW rotation.
A brass drift would be the first choice, but a steel drift won't do any real damage. If you don't have any store bought soft jaws, a couple of pieces of wood would work.
Make sure the clutch gear (input shaft) is held securely and doesn't wiggle around. The sharp smacks with the drift must shock the retainer so things must be held tight.
Be sure to hold your mouth right, that's the secret.
Stuart
I noticed when I rebuilt mine that someone had taken a punch or chisel to the threads. This was pretty common as a way to make sure they didnt come apart in the future. I had to file what I could and work that retainer back and forth with a punch and hammer to remove it. It was a pain in the @ss but I got it off eventually. I imagine you could use some sort of spanner wrench with the clutch gear stuffed in a vice.
Good luck, Jeff
My 1953 Chevrolet
1947.1 Gallery
Riding in the Passing Lane
Its been a long time but I think they are left handed threads. Take a good look at them or if someone has done one & remembers chime in here.
1972 Chevy c10 Cheyenne Super
Wrenchbender is correct, I was mistaken, the threads on the clutch gear ARE left hand. The retainer will come off in a CW direction.eek
Stuart
' Offline
rustednuts is correct...there is a SPANNER WRENCH
made for this difficult nut retainer.
see a pic of it here @ photobucket.com
just click on the link
http://i669.photobucket.com/albums/vv57/glp0329/KentMooreJ2670.jpg
it took me 6 months to hunt this tool down.
It finally came up on ebay.
G.
1954 3600
Now cruising in
The Passing Lane
1 Offline
I thought so! However, the good news I put a punch in one of the holes and gave a light whack in the CW direction and it spun right of with any effort. sheeesh.
