4 members (54farmtruck, klhansen, Rich'sToys, Southerntruck), 346 guests, and 3 robots.
Topics128,167
Posts1,057,096
Members48,463
#451457 09/12/2008 1:48 AM
Found out last week that JCarter is planning to have the gas tanks made for the AD's. The only repop I have found so far is a company that makes them out of STainless and they are pricey at around $500.
Perhaps OlTrucks can give us an update if he sees this post.
Alvin,
In your tank hunt did you run across a TF tank for the stock location by any chance?
best wishes,
Les
Les, sorry to be so late answering but I've been "sorta sick" if there is such a thing and this puter has got to be "modified" this weekend!
I did not see any tanks but perhaps it would help to email Oltrucks here on the sige or call JimCarters and ask for Mike Taylor. He may have one outback laying in the used stuff. I will keep my eye open for one around here though.
I guess your all healed up no from the "buzz saw" deal. Say hello to Sarah.
A little update on the gas tanks from JC. I spoke with Jim at the Turlock swapmeet this weekend and he confirmed that he is in the process of having the gas tanks made for the 47/8 pickups and the 47/55 Panels/Suburban/Canopy Express. He does not have a date when he will have them, but he is through the process of getting them made. It is not in the catalog at this time.
He also had the rear window spring clips made for the 1947/53 suburban. These are the clips that release the sliding windows (4) and are mounted to the body. These are not yet listed in the catalog either. The 54/5 clips are not being made at this time and I doubt that he will have them made.
George, any idea on the material that JC will be making the tanks out of?
George,
What is the difference between the 47-53 and 54/55 sliding window clips (Chevrolet)?
Tim
Tim, the 47/53 window clips are spring steel and chromed. the 54/5 clips are of a little different shape and have a texture to them. Jerry's 55 GMC has the different ones from my 1948 GMC. Most people have never noticed the difference. Jim and I had this discussion on saturday and he had already confirmed the difference.
Maybe someone can post their 47/53 clips....Weeds?
Scott, probably the same material the Camero and Chevelle reproduction tanks are made from. He is getting them from the same vendor.
Thanks, George,
I have a few chromed clips (in cold storage at this time) but I do not know what year/make they are off of. My 54 Chevy did not have chromed clips. I always wondered what years used which types of clips (or, if the chrome clip was a GMC thing).
Tim
TIM, I also have the original chrome clips on my 1951 Chevrolet Suburban. Can you post a picture of your 54 Clip? I am going to take a picture of my chrome clip this weekend. Thanks....g
PS: If you have an extra 54/5 clip, Jerry (gmc55) Needs one.
OLTrucks
Unregistered
OLTrucks
Unregistered
There is three styles of clips, The ones Jim Carter's is reproducing (came off one of my 1951s) is the 1947- mid 1952 are basically flat with a curve in at the top and used on windows that use the stainless edge on the sliding window section. I the other is seen on BigSix302's 1953 GMC burb (maybe we can get him to get a photo on one) then you have the later coated lock tab used in the later 1953s - 1955 1st
George and others,
Are you referring to the spring clips ("chrome clips" or painted clips) )that attach to the inner body and keep the sliding panes from sliding forward? Or, are you referring to the stainless handle that goes on the sliding window?
The stainless steel pieces on the sliding windows are different for different makes (GMC and Chevrolet) and/or different years.
Tim
if it means anything i put a brand new gas tank on my 47[2nd series] between the rails in the same location like the other one was. but i did have to make longer holding straps and fit nice between the frame n the drive-shalf
care to chat write back
Tim, the clips that we are referring to, are the spring clips that attach to the body and prevent the windows from sliding on their own. The 1947/53? are chrome, not stainless. The 54/5 clips are painted and textured. I was not aware that there are three clips, one for the 53 only.
I was also unaware that there were different sliding handles. I may have seen two types, but I can't confirm that. I brought my camera up to take some pictures, but have been busy installing a three phase converter in the new shop. I will take some tomorrow, I hope.
Post any pics that you have......g
The next question in this scenario is what about the fuel sending units. Will they be making a repop for thee tanks????
I don't suffer from insanity, I enjoy every minute of it!
I can't speak for Jim, but when we had the discussion, he was under the assumption that a truck sending unit could be modified to work. I told him that we concluded that it would not. Maybe OlTruck will chime in on this!
John Romero who often posts this board made another part work. Here is the original post and this is the actual part he used.
that 'original post' appears to be missing George, but I can 2nd that a universal sender can be fit to any rectangular tank [have one now for a new custom tank for daBus], and they can be obtained from most FLAPS, just make sure it's 30 ohms .... also, using the rotten origial sender on my 57 panel as a pattern, modifying the pickup tube and float arm on a repro pickup unit worked fine, don't see why it couldn't be done for an AD
All of the above might be complicated by how the tank is configured for a pick-up tube and sender unit. Some panel body tanks (54-55?) came with one opening on top for a dual unit, and it seems that other panel body tanks (47-53?) might have come with two holes for separate units (is that right)?
