| | | Forums66 Topics128,022 Posts1,055,269 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I put one on my 58 & it improved the handling/driving. One thing I would stay away from is the steering stabilizer, sideways shock absorber. I tried one of those & it was scary. They do work good on vehicles with power steering though. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Dec 2000 Posts: 163 'Bolter | | 'Bolter Joined: Dec 2000 Posts: 163 | Hello!
Sway bars were used on panel trucks in 41-46. I'm also interested in installing one on my truck, but information is hard to come by. Maybe one the panel guys out there could offer some information!
Randy B. | | | | | Joined: Jul 2000 Posts: 2,187 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,187 | Anti-roll bars are a good idea.
Don't know if the the one in your link will fit a '46. However, $139 (or $149 for the plated model) looks like a good price. I should consider one of those for my truck.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | If you are looking for a testimony on this; I can assure you if you put sway bars front and rear you will love the change.
~Jim
| | | | | Joined: Feb 2000 Posts: 5,190 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,190 | I just bought one of the sway bars like the above link shows. It just came yesterday and looks really well built,I paid $139 plus shipping since its powder coated and not the plated one.
I plan to install it on my '37. It shouldn't be much different then the 41-46 or even the 47-54 chassis. I have a original Chevrolet sway bar from a '39, but I think it might be from a car and adapting it looked to be complicated.
I will keep you posted on the instillation. Joe | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | I'm running the factory front bar on my 46 pickup, works good and it's a bolt-in. I was lucky finding a smashed 46 suburban in a wrecking yard many years back and got all the bits and pieces. I believe I paid around $10! | | | | | Joined: Feb 2000 Posts: 5,190 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,190 | Jim, you have any pictures of the '46 sway bar? Maybe I can identify mine. Joe | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Hi Joe H. I can take some pics for you, cannot post but could send via email. Let me know exactly what info you need. There are unique bracketry on these truck sway bars where it attaches to the springs and frame etc. | | | | | Joined: May 2005 Posts: 96 Shop Shark | | Shop Shark Joined: May 2005 Posts: 96 | Hi, Can You include me in Your Email ? Thanks, Jan [email protected] | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Jan, I sent you a private email. As these sway bars only came on panels and suburbans they are very difficult to find. An aftermarket bar shouldn't be to difficult to make work. Good luck Jim | | | | | Joined: Feb 2000 Posts: 5,190 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,190 | I got the sway bar mounted on my '37 yesterday. Its the '47-'54 sway bar all the venders sell. It was a easy swap and only took one extra bracket to make it work. I am working on a tech tip to show how it went together if I can get Peg to posted for me. Joe | | | | | Joined: Nov 2005 Posts: 238 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 238 | This kit will fit your front axle OK because it picks up the axle mountings between the springs; the spring spacing on your '46 is the same as on the later trucks. If you have the front crossmember in the same place as the later trucks, the two chassis brackets that come with the kit should fit as well. Here's a photo of this swaybar fitted to my '50 truck to give you an idea of what it looks like installed. http://i103.piczo.com/view/3/h/b/5/2/u/p/w/0/w/z/t/img/i279279759_79304_5.jpgStuart. | | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | Joe H, I'd like to see your tech tip. I've been pondering putting a sway bar on my 46 but wasn't sure about the fit. If it fits on your 37 it should work on my 46. Thanks George | | | | | Joined: Nov 2007 Posts: 39 'Bolter | | 'Bolter Joined: Nov 2007 Posts: 39 | I'm looking forward to it too. If it fits the '37, it will for sure fit my '38! And Buford could use a little help getting around corners. | | | | | Joined: Jul 2006 Posts: 451 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 451 | Ok, maybe I will add sway bars. But this is where I draw the line on the mods! Cavebull | | | | | Joined: Feb 2000 Posts: 5,190 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,190 | Peggy said she would try and have the tech tip up this weekend. Joe | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I need to do this to my truck, too! Only about three or four more mods, and mine will be as good a 2008 model!! Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: May 2008 Posts: 5 New Guy | | New Guy Joined: May 2008 Posts: 5 | will this work as well with a must. 2 crossmember? my panel did have one but i am not keeping the original susp. under it
| | | | | Joined: Feb 2000 Posts: 5,190 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,190 | I would think it will since most of the vender's sell sway bars for the MII, just check out e-bay, you will get a 100 hits for MII sway bars. Joe | | |
