Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (WICruiser, Guitplayer, Southerntruck), 46 guests, and 1 robot.
Topics128,009
Posts1,055,293
Members48,419
#487925 12/30/2008 5:39 PM
Tried to sandblast yesterday using a pressure sandblaster and Black Diamond media. Have used this same setup before with good results when I did my cab. Anyway, had trouble with the tip constantly clogging. The media was new in the bag and even a second bag did the same thing. It seemed like a piece of it would go at an angle thru the tip and get stuck. I tried the largest tip and still same problem. Any one with any ideas?
You could have problems with moisture clotting the sand...
I run my sandblast cabinet thru a dessicant air dryer first.
High Humidity can ba a problem.
GMC: Get More Cash...
1958 GMC
My Webshots photos
I did the same thing a couple weeks ago with the Black Diamond. The media is too large to fit through the ceramic tip on mine. I have not had time to look for a larger nozzle tip, but I would think one would be available. The media was not damp/wet, it is just as you have said. It gets a large piece jammed and the whole thing backs up. I used 50 LBS of aluminum oxide through it the week prior to the Black Diamond and it worked great, but way too expensive @ $40.00 for 50 LBS. The Black Diamond was $7.95 for 50 LBS. Maybe I got what I paid for?
1957 Chevrolet 1/2-ton Stepside LB in the Gallery
My Photobucket shots
The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873)
Good blasting sand should do the job. Good blasting sand is sized and consistent and cost only 3.28 a 50 lb bag here.
Now, I have had the same problem and I agree with 58GMCnut. One day I would blast just fine, the next day it clogged constantly. It has a LOT to do with the moisture. I know mine was not plumbed to be dry enough for blasting so I finally gave up, sold the pressurized blaster!!
I use the Black Diamond often and like the results, but sometimes it gives me fit's. When this starts to happen I will empty the pot out and sift the media thru a large tea strainer and the problem goes away. They have the media in different grits, and the fine is what I use most of the time but the medium grit is the one that gives me the most problem's so usually I just sift it first.
You Learn more Listening than Talking
What is a tea strainer and where would I get one? I need to sift the Black Diamond media so I can use it, since I have 100 pounds of it.
Alan - a piece of fly screen on a bucket works well, about the right size mesh
Like the screen on the outside of a house window, or screen door?
yeah - unless ya got smaller flys usin one or the other grin
usually a fine mesh fiberglass "hardware cloth", always called fly screen here
Thanks Bill. I don't want to waste all that Black Diamond media.
Moderated by  MNSmith
