4 members (Gdads51, Hotrod Lincoln, artinva, RoadsScholar), 62 guests, and 1 robot.
Topics128,078
Posts1,055,936
Members48,430
#487345 12/29/2008 12:48 AM
Will a Carter YF 2100S M87 fit a 1955 235 motor?
JohnGott
1942 G5106 1.5-ton Chevy cargo dump Gallery page
Old Dominion Stovebolt Society
T/Sgt. Gott (28 years of service with the USPP)
1940 Chevy G506 4112 cargo dump
1942 Diamond T G509 969A 4 ton wrecker
1942 Ward LaFrance G116 series 2 10 ton wrecker
1944 Ward LaFrance G116 series 5 10 ton wrecker
1931 Ford AA with a WEAVER crane
1944 Sterling HC 165 tractor
1944 Autocar U7144T w/ 10 ton trailer
J Gott #487895 12/30/2008 2:15 PM
ODSS Lawman
ODSS Lawman
I am not familiar with the numbers that you have listed, but a Carter YF is a direct drop in to replace a Rochester. I replaced both of mine because I was sick of dealing with the leaks. I did not even have to change the fuel lines.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
SWEET #487897 12/30/2008 2:29 PM
Sweet;
Thanks for the info
J Gott #487917 12/30/2008 4:34 PM
I have a Carter YF on the '54 235 in my '46 1/2 ton.
David Bush
J Gott #488124 12/31/2008 3:31 AM
Apprentice
Apprentice
The original Carter replacement for 1950-59 models with 235 was 966S. Carter later superceeded it with number 2100s. So yes, it will fit.
Just make sure you get the Chevy version. There is a Ford version of the 2100S, but the jetting is about 150-200% richer than one for a Chevrolet.
Bill Burmeister
LONGBOX55 #726776 03/04/2011 11:52 PM
I know this is an old post, but can anyone tell me where to find one of these YF Carter carbs. I've got a 235 out of a '55 bel air and I want to get rid of the Roch, but I want to stick with just one carb and not spend a fortune. I've read so many bad posts about the single H/W I think I want to stay away from that. This sounds like it would work but where do I find one?
I did see this (sorry, I can't find out how to add a clickable link, please copy and paste this if you wold?): http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_Carburetor-United-Carb_3451097-P_26_R%7CGRPCARBAMS_1261785240___
it says its a "united" carb, but it does say its a "YF"
'53 Chevy 3604 Five Window Cab ('56 235)
