2 members (dt235sd, 1 invisible),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,679 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 242 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 242 | Will a Carter YF 2100S M87 fit a 1955 235 motor?
JohnGott 1942 G5106 1.5-ton Chevy cargo dump Gallery pageOld Dominion Stovebolt Society T/Sgt. Gott (28 years of service with the USPP) 1940 Chevy G506 4112 cargo dump 1942 Diamond T G509 969A 4 ton wrecker 1942 Ward LaFrance G116 series 2 10 ton wrecker 1944 Ward LaFrance G116 series 5 10 ton wrecker 1931 Ford AA with a WEAVER crane 1944 Sterling HC 165 tractor 1944 Autocar U7144T w/ 10 ton trailer
| | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | John
I am not familiar with the numbers that you have listed, but a Carter YF is a direct drop in to replace a Rochester. I replaced both of mine because I was sick of dealing with the leaks. I did not even have to change the fuel lines.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Aug 2004 Posts: 242 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 242 | Sweet; Thanks for the info
John 1942 G5106 1.5-ton Chevy cargo dump Gallery pageOld Dominion Stovebolt Society T/Sgt. Gott (28 years of service with the USPP) 1940 Chevy G506 4112 cargo dump 1942 Diamond T G509 969A 4 ton wrecker 1942 Ward LaFrance G116 series 2 10 ton wrecker 1944 Ward LaFrance G116 series 5 10 ton wrecker 1931 Ford AA with a WEAVER crane 1944 Sterling HC 165 tractor 1944 Autocar U7144T w/ 10 ton trailer
| | | | | Joined: Oct 2008 Posts: 298 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 298 | I have a Carter YF on the '54 235 in my '46 1/2 ton.
David Bush | | | | | Joined: Nov 2008 Posts: 12 Apprentice | | Apprentice Joined: Nov 2008 Posts: 12 | The original Carter replacement for 1950-59 models with 235 was 966S. Carter later superceeded it with number 2100s. So yes, it will fit. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Just make sure you get the Chevy version. There is a Ford version of the 2100S, but the jetting is about 150-200% richer than one for a Chevrolet.
Bill Burmeister | | | | | Joined: Jun 2009 Posts: 235 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 235 | I know this is an old post, but can anyone tell me where to find one of these YF Carter carbs. I've got a 235 out of a '55 bel air and I want to get rid of the Roch, but I want to stick with just one carb and not spend a fortune. I've read so many bad posts about the single H/W I think I want to stay away from that. This sounds like it would work but where do I find one?
I did see this (sorry, I can't find out how to add a clickable link, please copy and paste this if you wold?): http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_Carburetor-United-Carb_3451097-P_26_R%7CGRPCARBAMS_1261785240___ it says its a "united" carb, but it does say its a "YF"
'53 Chevy 3604 Five Window Cab ('56 235)
