| | | Forums66 Topics128,151 Posts1,057,009 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 117 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 117 | Are there any disadvantages of using fiberglass fenders and running boards other than the resale value of not being steel who's would you recommend putting on | | | | | Joined: Apr 2005 Posts: 381 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 381 | A lot of the fiberglass fenders don't always fit that good. With a steel fender you can slice and dice and weld to fit. The procedure of doing that on fiberglass is a little trickier. An experienced body man working with fiberglass can make it happen.My choice is to always go with steel fenders. My buddy drives his '52 Chevy pick up year round in the snow and salt up here in Boston. He put fiberglass fenders on, so he'd have no worries with rot. The fenders don't look that great, but it's a daily work truck. From 20 feet away the fiberglass fenders look OK. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | used all fiberglass fenders and running boards on my 37 and have never regretted it. I've been running mine since 2000 and NO problems. A couple companies out there make and sell them but my choice is R&R Fiberglass out of Tenn. 423-334-4455 Richard has been in business for many years and has good quality. Tell him ole Alvin said to give him a call. You'd be surprised how many knowledgeable folks peck on my fenders and think they are steel....or can't seem to tell the differnce real easy. They fit and still look good.
Edit: I've used other fenders from R&R and always good quality.
| | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Im runnin glass rear fenders on my 52 an they fit GREAT! I was suprised on how good they fit the contours at the runnin board junction. For me it was lookin at double the price in labor to fix up my steel ones that BADLY messed up from my uncle the PO runnin chains in a snow storm that destroyed the lower rear sections. Im pretty happy with my glass rear fenders. Tim | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | I bought fibreglass rears for my panel. I couldn't find a good used pair in steel. They look good to me, will be putting them on this winter. | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | I bought a set of rears for my'40 from a place in Oregon. They didn't even come close to fitting correctly. To their credit, they took them back and gave a full refund. Quite a few on this board have recommended R&R Fibreglass. In the end, I was able to find a pair of used steel fenders that didn't need too much work. At the end of the day, unless you are trying for a totally stock truck, I think good quality glass fenders are fine - many trucks and cars out there with glass parts. | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | check out http://www.usbody.comThat is where i got mine. | | | | | Joined: Dec 2007 Posts: 180 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 180 | I used the 3 inch wider rear fenders on my truck from Verdine Performance they look and fit good. | | | | | Joined: Feb 2000 Posts: 5,232 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,232 | All four of mine a glass and I am real happy with them. Steel is great if you can find them, but it all comes down to how much time you want to invest in looking. Joe | | | | | Joined: Nov 2008 Posts: 117 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 117 | sounds like l should give them a try is there any place in Canada to purchase them
| | | | | Joined: Oct 2005 Posts: 275 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 275 | Here is a set listed on Craigslist
38 original 48 panel 59 stepside 46 in the back forty
