2 members (Joe H, moparguy), 118 guests, and 2 robots.
Topics128,093
Posts1,056,480
Members48,444
on 47-49? the windlace retainer is screwed on the cab does it go over the windlace? or does it have a channel like the later spot welded AD retainer that the windlace slides into? does someone have a picture of the early style?
1949 SUBURBAN
There are several clips that go over the windlace, no channel to run it through.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
IS THERE ANY VENDORS THAT SELL THE LATE AD RETAINER CHANNEL
1949 SUBURBAN
John,
Call Classic Parts of America - they used to sell a 36" piece of replacement channel (they now sell this for each side - is this it?) . And/or, call Jim Carter, he might have pieces of used channel.
Tim
THAT APPEARS TO BE IT NO PICTURE YET THE UPHOLSTERY SHOP REMOVED MINE 25 PLUS YEARS AGO AND PUT WINDLACE LIKE A CAR WHEN I WENT TO PICK IT UP
1949 SUBURBAN
Jim Carter is now reproducing the channel in 12" straight lengths. Part number CB350 it is expensive at $16 a pop. When I replaced my inner cowls I used these pieces I purchased from JC and they worked great.
Brad: I had not noticed this in Carters catalog so THANKS for mentioning it. I need one piece about that long. I was going to get a "tin bender" to make me a small piece but for $17 and couple for shipping I don't think I can beat that. Thanks again.
Question:
The body man took the passenger side loose from the kickpanel up to the top of the door. I have noticed he replaced it with flat head screws. It appears the rubber will hit the heads of these screws and not be able to slide through. I don't have a spot welder so how do I deal with this?
~Jim
As usual I forgot to check to add as a watched topic. dang
~Jim
OOPS... wrong windlace frown
Woody
Door Art Collection
Moderated by  ndkid275, Phak1
